how much power is a ls6 intake good for
bottom line is it takes a lot of money the deeper you go into making hp.
Ive tested them all on various application from stock to wild, and its almost always even from idle to 3500RPM. After 3500 RPM you will see 10-15hp over an LS6.
i was talking about the 102mm fast for stock cubes (not worth the money for the hp/tq)..
.. Bigger isn't always better .... for the OP ... please don't use the words of the forum members as a guide ... use our opinions for your research only .... FAST intakes are mostly a good upgrade for a very mild setup .... i don't see much better gains with upgrading only your Intake Combo ..... power adders are your best bang for the buck at this point. True but do the math your self at this point with a 1200$ budget ..... loss of tq below the 3k RPM or maybe even equal power below 3K RPM .... does your car see above 4K often ??? are you willing to spend 1K more or less for 10-20hp only above 4K ???? I say go FAST if your in it for the looks under your hood
go NOS if you really want a big diffrence in your HP/TQ.drive by
And for the love of God, nitrous. Nitrous. Nitrous.
dead horse much?
