Fast 102 fuel rail set up ..pics please!
This is for when using OEM LS2/LS3 rails only
LS1 injectors require a small spacer between the fuel rails and the manifold to raise the rail for the longer injectors. #146021-kit (rails and spacers)
LS2 injectors bolt on, nothing needed, this is what the intake was designed around.
LS3/LS7 injectors require the small spacer cups on the bottom of the injector because they are so short. #146025-kit (spacer cups only)
The FAST billet rails all have there own specific kit with proper mounting brackets for each specific length injector.
#34
I do know that you cant use the old fuel rails though, if thats why your trying to get just the brackets. The way I was told to know if you can use your fuel rails or not is to look at the bracket mounting holes. If there are only two holes, you have to buy new rails. If your fuel rail has three holes, you can just buy the correct brackets.
I found this pic on google showing the three hole style rails.....
![](http://www.cpgnation.com/forum/attachments/1769d1293478207-fast-lsxr-lsxrt-billet-fuel-rail-146027-kit.jpg)
#40
No problem guys, want to know my secret?????
FAST puts this information out for you, most people just dont look for it(including vendors who sell their stuff)! If you goto the FAST intake manifold parts selector website, you can find everything you need. If your doing something custom, then you select based on the injector you have.
For example; If you using LS2 injectors in your Mustang with the FAST 102mm intake, select any car with an LS2 designation on the selector. Example; "Chevrolet Corvette (LS2)"
Then I selected that I wanted to use FAST Billet rails, and it gave me the part number to answer the OP.
Try it guys,
http://www.fuelairspark.com/Company/...mSelector.aspx
Try it guys,
