Combining Ram Air setups
Old Jan 20, 2011 | 03:33 PM
Suzaku's Avatar
Default Combining Ram Air setups
Anyone here ever combine a SSRA/FTRA/Chris1313, Sux2BU/FLRA(Fog Light Ram Air), and JAAM/BGRA in their intake setups?
What kind of performance gains would be expected?
Old Jan 20, 2011 | 08:05 PM
Zmg00camaross's Avatar
HAHA double ram air damn. I dont know if it would build anymore pos pressure or not, Would imagine there is only so much you gain from a good ram air system.
Old Jan 24, 2011 | 02:53 PM
SINCWS6's Avatar
I've been wondering this same thing. What would happen because you'd be forcing air from the bottom and from the top. you know ive always been told "more air the better" but would this work good. I really want the BGRA set up but you can't buy it anymore. I guess the guy quit making it.
Old Jan 24, 2011 | 07:59 PM
Suzaku's Avatar
Well regarding this, I am currently working on a setup where there is ram air on the hood, the foglights, and the underside. A poor man's supercharger I guess.
Here's a pic of what I was doing today, foglight ram air is next on my list.
Old Jan 24, 2011 | 08:05 PM
kinglt-1's Avatar
Old Jan 24, 2011 | 09:10 PM
trans_am7935's Avatar
now all you need is a good old fashion roof scoop! then you will be set for life!
Old Jan 24, 2011 | 09:14 PM
Suzaku's Avatar
Yeah, it'll help cool my engine in the back.
Old Jan 25, 2011 | 09:45 PM
ss1le02's Avatar
Did you paint your cold air kit under the filter black?
Old Jan 25, 2011 | 10:39 PM
Suzaku's Avatar
Nope, that's your ram air kit.
I bought it off of E-bay about a month and a half ago, why aren't you selling it anywhere else anymore?
EDIT:
Oh, I can see how the picture can be confusing. The blackish grey part above the layer of clear silicone is the WS6 Air Box.
The rest of the CAI continues to run under the WS6 Airbox, but it is sealed off by the silicone.
Old Jan 28, 2011 | 12:54 AM
Blklsxws6's Avatar
I wonder if multiple ram air setups would be beneficial to a larger cube engine like a 416 or 427. For example combining the jaam kit with the chris 1313 but wasn't sure if the gains of using both would be measurable over using one or the other alone.
Old Jan 28, 2011 | 11:28 AM
5.3LJimmy's Avatar
It has been proven that the air pressure will actually escape thru the front of the air box and it works better blocked off. That is why the scoop type ram air kits block the front of the air box. You need to have it sealed up to keep the pressure in otherwise you are defeating the purpose.
Old Jan 29, 2011 | 12:38 AM
Suzaku's Avatar
Well, the problem with all of those cases was that the scoop on the hood was not sealed to the airbox.
I've sealed the ram air scoop on my hood to the airbox, but I have yet to put it through a dyno yet.
I'll keep you guys up to date on what happens when I put it through a dyno and cover each one of the ram intakes individually.
Old Jan 29, 2011 | 12:59 AM
zracer323's Avatar
Keep in mind that air will always flow in the path of least restriction. If you have 2 sources of air trying to pressurize the same plenum, one source will dominate unless both sources are exactly equal in pressure. So in this case having 2 sources of air will hurt not help bc you won't be able to properly pressurize the airbox which is the whole point of RAM air
Old Jan 29, 2011 | 01:17 AM
Suzaku's Avatar
There are three sources when it comes to having 2 ram air setups.
The first source, the engine is providing vacuum.
The second source, the hood ram air.
The third source, the under-body scoop ram-air.
And the lowest source of resistance is the engine which is providing negative pressure.
So unless the intake is being pressurized at a rate faster than the first (Higher than 1 PSI) source (engine), there shouldn't be any backwards flow or loss in effectiveness. And I doubt that Ram-air reaches 1PSI when working with an engine under full load. What it does do I think, is decrease the amount of effort required for the engine to pump air into itself, thus the horsepower gain. Of course, this depends on the speed at which the vehicle is traveling.
I will be stealing a spare boost gauge from my brother really soon to test my theory at 80mph.
Old Jan 29, 2011 | 11:33 AM
LS1W66's Avatar
While I'm no physics expert I'm inclined to agree with this.
I've had a Debaffled Hood and FRA for 12+ yrs now with no adverse effect on performance. Even if the Air is forced from one portal to the other it's still being injested by the engine under WOT.
Old Jan 29, 2011 | 12:49 PM
Blklsxws6's Avatar
I doubt that running two ram air systems could hurt performance but exactly how much it would help is the question. I think the gains would be much greater on a large cube engine with larger tb, intake, etc than on a stock cube engine w/ bolt ons especially in high speed wot conditions. Just my .02. Keep us posted on your tests Suzaku.
Old Jan 31, 2011 | 09:56 AM
5.3LJimmy's Avatar
Actually I was referring specifically to cars that had the hood sealed to the lid along with a scoop type ram air setup. The dyno will not show you true results as you can not get enough airflow to simulate how much pressure is generated with the car in motion.
You can only accurately test this at the track, and it has already been done. The scoop style under the car is in a higher pressure area and will force more air into the lid than the lower pressure area of the stock ram air scoops. I promise you that if the lower air box is sealed to block the factory air path the car will be faster down the track(or on the road for that matter). I'm pretty sure Chris1313 is one of those that actually tested this theory, but there are others here as well.
Leaving the front of the airbox open is going to allow the high pressure air forced in from the scoop to escape. As stated by zracer323 above the air will take the path of least resistance. That path is straight out the front of your hood.
I'm only trying to save you some work by sharing what others have already tested. You sound determined to find out for yourself and that is a good thing. Please share your results when you get them so others can benefit from it.
Old Feb 1, 2011 | 02:30 PM
Fast Toys Performance Parts's Avatar
Default Ftra
We have tested the FTRA multiple times and it is faster with the front seal in place.
