What type of wideband to buy?
my car is stock with an airfilter and magnaflow muffler. i just programmed with Diablo predator and just need something to monitor the A/f. what would you all recommend?
I'm rockin the NGK. It's great if you're going to use it for datalogging but not so great if you just want to look at the gauge. For some reason NGK defined stoich as a slightly different number than optimal for the readout. I hid the gauge so I couldn't see it If you're looking for something to datalog with then I doubt you'd find anything better. All HPTuners sees is a voltage, and you have to define what the voltage level means. In other words, it reports flawlessly to the datalogger, but doesn't report the actual value on the gauge.
