Lsxr vs lsxrt
Old Feb 4, 2011 | 11:46 AM
TXsilverado's Avatar
Default Lsxr vs lsxrt
i know ive read a little about it on here somewhere but a search is finding nothing. im lucky enough to run either one, and have a few guys interested in my ported fast 90mm setup. im just looking to go to a stock 102 setup with a 90mm throttle body. what are the differences?
Old Feb 4, 2011 | 05:47 PM
madball's Avatar
GMHTP just had an article on it with a tbss
Old Feb 4, 2011 | 06:03 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Since you have enough room to run the LSX-RT, you would ideally go with that. You'll end up with more power across the board - the only downside is that it looks a little goofy since it is so tall, but the increase in performance would probably more than offset that.
Old Feb 4, 2011 | 11:25 PM
Link?
Evidence?
not meaning to call anyone out on their answer. just looking for a little substance to the answer. hard data/experience is always nice
Old Feb 5, 2011 | 10:06 AM
MeentSS02's Avatar
Google:
http://www.gmhightechperformance.com...ade/index.html
Old Feb 7, 2011 | 09:32 AM
ah, i found that, but thought madball meant that gmht did a comparison between the 2 intakes side by side.
Old Feb 7, 2011 | 06:33 PM
SweetS10V8's Avatar
They did, LSXRT +50hp over the stock one
LSXRT makes more power than LSXR. I've tested it myself. The runners are straight in LSXRT and it has a lot more plenum volume
Old Feb 8, 2011 | 12:17 AM
hitmanws6's Avatar
The truck specific design has the taller runners for low end torque. Its more of a hassle to run the LSXR on a truck motor because you need to relocate accessories. The RTs go for cheap with little miles or just dyno runs on them
Old Feb 12, 2011 | 03:26 PM
it would actually be more of a pain for me to swap BACK to the truck style. im already running a ported fast 90mm on my truck.
Old Nov 25, 2011 | 04:53 AM
Karl101's Avatar
So the LSX-RT is better than the LSX-R. Is that for trucks only or can you put it on cars too? I got the outlaw hood on my TA and it has plenty of room.
Old Nov 25, 2011 | 08:57 AM
dodson55's Avatar
The cowl will be where the problem is on a ta not the hood
