Another position for PCV catch <pics>
Old Feb 14, 2004 | 03:44 PM
SSN8R's Avatar
Default Another position for PCV catch <pics>
OK I decided to do the compressor version of the catch. I was not experiencing any oil consumption, but I could see some oil was getting through.
I placed my can right next to the normal connection. Looks a little cleaner to me. I had to move the hose outside of the breather hose along the valve cover. It is only an inch from the original position. Only took 10 minutes.
Try to ignore the dirt. Car was in the body shop for some custom paint and I have not had a chance to clean the engine compartment yet.
Pics are here.
They are a little big for dial-up if you click on the thumbnails.
Enjoy...
Old Feb 14, 2004 | 03:49 PM
DaleMX's Avatar
Nice Idea, I'll see if I can second that.
Old Feb 14, 2004 | 04:32 PM
highgear's Avatar
Nice setup. What is the part# and where did you buy it?
Old Feb 14, 2004 | 04:50 PM
SSN8R's Avatar
That is the Campbell Hausfeld Mini General Purpose filter model MP5138. It was in the air compressor accessory area at Auto Zone.
SSN8R
Old Feb 21, 2004 | 03:09 PM
Casper9T9's Avatar
I did this today and replaced my pvc pipe catch can. I like it much better. The only thing I did different was place it before the PCV valve. I had to use an elbow to make it fit the way I wanted. It looks much cleaner than my old setup.
Old Feb 22, 2004 | 09:55 AM
Black Sunshine/ 00SS's Avatar
Looks nice. How is going to hold up to the heat in the engine compartment? Was it built to handle heat?
Might be worth trying, along with the LS6 valley cover.
Old Feb 22, 2004 | 10:01 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I looked at that CH can at home depot, but I thought I read that it was not to be used above something like 15X or 17X degrees (can't remember which)? My motor get hotter than that, so I was worried about the glass breaking eventually.....
Old Feb 22, 2004 | 02:44 PM
I just looked at it at Auto Zone, and it is a nice piece. It does say not to use with Synthetic oils, and a list of other things, that I asume will break down the plastic glass over time.
I didn't see anything about heat. I think if spaced far enough away from the block, it should be ok. I might have to give it a try.
