Custom CAI
Old Feb 27, 2011 | 08:36 PM
McNord's Avatar
Default Custom CAI
Looking for thoughts on cai setup I've been working on, still being mocked up so ignore the tape lol. Think I'll have any overheating problems or anything? As it is right now ALL the air coming in will be from the front but I will be opening up the whole grill area & covering with something similar to a billit grill.
Old Feb 27, 2011 | 08:47 PM
chrs1313's Avatar
looks good but it won't really pressurize that much do to it not being sealed up just to the intake...but all the added alumin should help the radiator get plently of air...
I would close off each air filter facing the front grill...like a small individual air box for both...it will give you the added hp by turning it into a ram air setup as well as a cold air setup
Old Feb 28, 2011 | 12:31 AM
sjsingle1's Avatar
you have 2 BIG filters necked down to the size of 1.....would it be better to use a larger size pipe to the TB?
Old Feb 28, 2011 | 01:41 AM
McNord's Avatar
Yes, I thought of that too but I also figured only so much air can get through the MAF anyway & the tubing is still .5" larger in diameter than the MAF. I know theres larger sensors available but haven't seen too much on them & what I did see required other things to be done at the same time that I'm not ready ($$$) to do.
Old Feb 28, 2011 | 01:42 AM
BOBS99SS's Avatar
Captain Double Post
Sj,how much room do you think there is in there for that lol,I'm guessing from what I can see its about as tight as it can get,nice work,looks sweet
Old Feb 28, 2011 | 01:44 AM
McNord's Avatar
Thanks, & yes, I did use up every bit of room I had to work with lol.
hitmanws6's Avatar
Should work well, the C5s have a similar kit available for them and ive never heard any complaints from them
Old Feb 28, 2011 | 02:09 AM
sjsingle1's Avatar
stick some bigger pipe on there and use a SD tune
Old Feb 28, 2011 | 05:54 AM
ZYA_LTR's Avatar
I really like the look of it, but i'm wondering,.......unless the area that contains the filters is totally sealed and allowed to turn into a "ram air" type setup,(which would be hard to do with gaping holes in the front) this is essentially another form of "cold-air" induction??? am i right? If so, i would be hesitant to toally seal off the radiator only allowing the incoming grille air to feed it, as the system was designed to be fed from the bottom of the car. Now i could be wrong, but, i would definetely be prepard to modify your front scoop to switch over to allow the back/bottom are to open up, and just have the side scoops there, or toally remove that and leave the pieces on top. Very nice design and work though....Might be the next "user made" cold air to be sold by the sponsors. I would even be willing to just try the radiator support piece, and the dual snorkel setup. I do beleive that although you are going from 2 to 1 inlet, that the dual snorkels...due to placement in the airstream....will benefit you with fresher/cooler air than a single relying on indirect flow.
Old Feb 28, 2011 | 01:14 PM
McNord's Avatar
Thanks for the compliments,
I think I'm going to take chris1313' sadvise & make a sheild on the back side of the filters to direct the air better.
ZYA LTR-I am also prepaired to cut a slot at the back of the bottom peice to allow the air from underneith to come in, but I want to test it out first.
I know as far as cold air into the TB its going to be much better than what I had, I was using the K&N setup & its design pretty much seemed to block any air from getting to it.
Old Feb 28, 2011 | 02:12 PM
ZYA_LTR's Avatar
You get bored and feel like making a spare radiator cover, lemme know, i can have the tubing for the filters/TB fabbed up, but i like the looks of your sheetmetal cover for the radiator.
Old Feb 28, 2011 | 07:44 PM
Behemoth's Avatar
nice. I dig the placement of it.
Old Feb 28, 2011 | 08:07 PM
RoidedSS's Avatar
pretty interested to see how and IF this works. looks real clean good work man
Old May 11, 2011 | 12:19 AM
Joeyc617's Avatar
Looks NASTY! I wanted to do a similar setup as well, where are you getting the intake pipe from? part numbers?
Old May 11, 2011 | 12:52 AM
AwsmGy's Avatar
Would you be able to access that from the top? Taking off the front bumper to change/clean filters would suck.
Old May 11, 2011 | 01:14 AM
Starz T/A 17's Avatar
That's what I was thinking, my friend has a RX8 and got a CAI kit and we had to take off the front bumper and bumper support to install it. And that has to be done when you replace/clean the filter.
Old May 11, 2011 | 02:37 PM
Pocket's Avatar
Looks nice and should flow well
You and your passengers are dead in an front impact though. That big steel bar up front isnt just to bang your knuckles on
Old May 11, 2011 | 02:39 PM
McNord's Avatar
Thanks guys, actually there was a change in plans at the very front on top, access to the filters is pretty easy. Don't have to remove the nose or anything, just take one panel off & it just clips on, don't need any tools.
In the intake tube there are no part #'s, I made it.
Old May 11, 2011 | 02:47 PM
McNord's Avatar
Guess we posted at the same time lol, Its taken care of now.
Old May 11, 2011 | 03:09 PM
Looks really good, And I really like the green accent, its really different but just flows well with the car
