Stall swap question
Old Mar 4, 2011 | 01:41 PM
cory32690's Avatar
Default Stall swap question
I'm about to swap my stall for a 4k stall will I be able to drive it with ok without getting computer tuned
Old Mar 4, 2011 | 02:19 PM
RARON455's Avatar
I dont think so,, thats a ton of stall I hope you have the hopped up engine to supply that converter.
Old Mar 4, 2011 | 02:25 PM
Jay-P's Avatar
A 4k stall will live happily behind a moderately breathed on motor... don't worry about that.
Old Mar 4, 2011 | 02:33 PM
Anniversary "Z"'s Avatar
what tranny?
Old Mar 4, 2011 | 02:38 PM
cory32690's Avatar
4l60e with a big tranny cooler I'm gonna prolly put a torquer v2 cam or something similar
Old Mar 4, 2011 | 02:39 PM
ws6fitz's Avatar
The answer is no. You have to get your car re-adjusted for the change in stall speeds. Your shift points will be off as well as the lock up points for the converter. Your car will run like a pos if you dont get it re-tuned for the new stall.
Old Mar 4, 2011 | 02:52 PM
ws6fitz's Avatar
Are you planning on not getting the car tuned at all??
Old Mar 4, 2011 | 03:13 PM
Do them both at the same time and tune once.
Old Mar 4, 2011 | 03:18 PM
PheonixLS1's Avatar
According to Frost ( I live 20min away from his shop) you can run your car without a tune on a bigger stall. I'm putting in a 3500 stall and he said all I have to do is pay attention to the manufacturers break in period and the " LET'ER EAT ".
Old Mar 4, 2011 | 03:42 PM
cory32690's Avatar
I planed on doin the frost mail order tune but I would just need it to be driveable on the street without dying on me
Old Mar 4, 2011 | 05:10 PM
cory32690's Avatar
If I get a frost tune alone and leave the cam alone will it drive ok
Old Mar 4, 2011 | 05:21 PM
ws6fitz's Avatar
Honestly, I would personally get a dyno tune. Its much more affective than a mail in tune IMO. No offense to Frost I am sure he does a great job with them, its just what I would recomend. It really sounds like you are unsure of what you are doing. So with that being said..... Do both the cam and the stall at the same time. Make sure you do some research and spec the cam and stall to work correctly together. Once you get both installed take it to a shop to dyno tune it.
Old Mar 4, 2011 | 06:36 PM
cory32690's Avatar
The thing is though I want to see how much time I drop with each new part I don't want to do everything at once
Old Mar 4, 2011 | 06:41 PM
cory32690's Avatar
It's not that I don't have my idea package made up..the goal is torquer v2 cam 4k stall and 3.90-4.10 gears and of course all suporting mods
Old Mar 4, 2011 | 09:37 PM
PheonixLS1's Avatar
IMO a 3500 stall would be ideal for what your doing. And again with a stall you DON'T NEED a tune. It will run fine, just make sure you do what the manufacturer suggest for break in and then drive it like you stole it.
Old Mar 4, 2011 | 10:26 PM
cory32690's Avatar
I drive it that way now I'm 20 now I got it when I was 17 went a best of 8.30 in the 1/8th @86.6 hopeing stall and tire will get me in the 7's
Old Mar 4, 2011 | 10:33 PM
cory32690's Avatar
Another reason I went so big on stall cause eveyone I talked to whether it was on here or local guys everyone says once they went 4k stall the would never gp back to anything smaller
