Hooker Y banging fix?
Old Feb 15, 2004 | 09:16 PM
1 SIC Z's Avatar
Default Hooker Y banging fix?
Can someone give methe link or parts list of the heater hose/header wrap mod with the hose clamps.....thanks
John
Old Feb 15, 2004 | 09:47 PM
wrencher's Avatar
wrencher
It's kinda simple, 5-6' header heat wrap a big clamp & some green emission tube hose.
Under the drivers seat (where it's prolly banging) the spot were it is hitting, wrap the heat wrap around.
Put 4-5" section of hose on clamp & use it to pad pipe from floor & to retain heat wrap.
Old Feb 17, 2004 | 07:10 PM
1 SIC Z's Avatar
ttt..help..give me some part #s and where to get this at...thanks
Old Feb 18, 2004 | 01:08 AM
Krab's Avatar
I don't have any links, but can offer my own experience. I see you have a Hooker ORY which is probably banging near the bend on the driver's side. Go to your local hardware store and buy those black, long rubber strechy things that you can insert hooks at the ends so you can hold stuff down in the back of a truck. I don't know what they're called and that's the best explanation I can give of them. Locate exactly where your Y-pipe is banging. You'll just need to cut a couple of 2" pieces of rubber and JB weld it to the floor board right where the pipe is banging. This should cure your banging Y-pipe.
Old Feb 22, 2004 | 01:16 PM
Mike01Hawk's Avatar
Won't this just turn the 'bang' into a 'thud' though?
<-- Has driver seat bang w/ Jet Hot Catted Y.
Old Feb 22, 2004 | 01:31 PM
James Creasy's Avatar
I need this fix also, my borla y - pipe bangs, especally when spinning.
Old Feb 22, 2004 | 06:24 PM
1BADAIR's Avatar
I had the same problem when I spun or while shifting hard. I installed a Prothane engine mount on the drivers side and have had no problems since.
Old Feb 22, 2004 | 09:16 PM
Krab's Avatar
Not really, you don't really feel it after you've put the rubber in. I thought this would happen also, but the rubber does a really good job at absorbing the impact. I honestly don't feel it. Just try it out and see how it works for you. If you don't like it, you've only wasted about $5 in supplies.
Old Feb 22, 2004 | 09:49 PM
robertbartsch's Avatar
I have the same problem with FLP long tubes; they bang like hell!
I bought some aluminum screening for household windows at Home Depo. I rolled these into bunches and clamed them to the Y-pipes between the pipe and the floor boards using extra large hose clamps....it works... ...no problem with burning the rubber hoses if you use aluminium screening instead...
Old Feb 23, 2004 | 05:58 PM
1 SIC Z's Avatar
what part no. is this? thanks
John
