Header bolt size?
Old Mar 15, 2011 | 02:12 PM
CNTLSE 1's Avatar
Default Header bolt size?
I think I am just going to get some stainless bolts from the hrdware store to use for header bolts. My question is what is the correct size to be running? I will be running TSP 1 7/8 headers. Thanks
D.J.
Old Mar 15, 2011 | 02:17 PM
5.7mmImportkilla's Avatar
head bolt is 1/2 inch...
not sure of the length..
Old Mar 15, 2011 | 02:32 PM
TheBlueKnight's Avatar
I just took out one of my stock header bolts (whichever is easiet for you to get to), and took it down to the hardware store and matched it.
Old Mar 15, 2011 | 04:13 PM
CNTLSE 1's Avatar
dont have the stock ones anymore
Old Mar 15, 2011 | 05:35 PM
shepss217's Avatar
they are m8 1.5mm thread separation, i would say about 50 mm long
Old Mar 15, 2011 | 08:41 PM
joecar's Avatar
M8x1.25
underhead bolt length: measure how far a bolt threads into the hole, add flange+gasket thickness, subtract 2-3mm, round down to available bolt length (typically a multiple of 5mm)... this will be something like 20-25mm;
e.g. those bolt holes are threaded 16mm deep, my header flange is 10mm, MLS header gasket is 1mm,
this gives: 16+10+1=27 then 27-2=25... so the size is M8x1.25x25;
header flange thickness varies among headers.
