Are MSD wires crap or is it me?
#41
Ive had problems with mine and my friends.
I cant get mine to pop when they go over the spark plug so its a guessing game as to if Im firing on all cylinders when i start the car.
My friends wires disintegrated when we tried pull em off after couple thousand miles.
#43
I like Taylor thundervolts myself, every time ive OHM'd them out they are always less than .005 resistance, ive even compared them to MSD and seem to have better resistance readings than they do, also the extra thick 10mm boots/sleeves help a lot from header heat... As a side note ALL wires must be put on with Dielectric grease in boots and installed and removed carefully or they will come apart.
#44
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Ran like a champ till I shattered a rocker arm. Cant say that I expected them to hold up to the spring pressures I'm running tho. I knew from the beginning that I should have been running Jesels. Not in a big rush to fix it tho with fuel prices and single digit city mileage.
