Wiring Issue?
Old Apr 12, 2011 | 09:09 PM
BlackBirds's Avatar
Default Wiring Issue?
Today I noticed when I turned my ignition on my passenger's tail light was lit up, but my driver's wasn't. When I push the brake pedal both lights light up as normal, but when I release it the passenger's tail light stays lit up. Does this indicate a fuse is blown or something like that? This car is a project drag only car, so a lot of the wiring inside has been unplugged, does anyone know why one brake light would come on when the ignition is turned?
Old Apr 13, 2011 | 11:53 AM
BlackBirds's Avatar
anyone know why the passenger's brake light would come on by itself when the ignition is on??
Old Apr 13, 2011 | 06:04 PM
BlackBirds's Avatar
i also noticed when i step on the brake pedal with the ignition is off only the driver's side comes on
Old Apr 13, 2011 | 07:34 PM
S10xGN's Avatar
You're prolly not getting an answer because the people who read here are expecting "gen III external engine" questions, not body wiring questions...
Old Apr 13, 2011 | 07:55 PM
BlackBirds's Avatar
i didnt know where else to put the question. There isn't a "wiring" section that I could see
Old Apr 18, 2011 | 11:32 AM
OldCobraGuy's Avatar
Sounds like a ground issue...feedback...problem.
Old Apr 25, 2011 | 02:13 PM
BlackBirds's Avatar
problem solved, the connections at the brake pedal were loose and needed secured to the pedal better.
Old Apr 25, 2011 | 07:08 PM
S10xGN's Avatar
Glad you found a fix!
