Having issues
So you changed o2's on both sides or just the one? If your only throwing a o2 code on bank 2, then it's either the sensor or connector/wiring. Thats why I suggested to swap sides and see if the code stays on bank 2... if it does then you got a wiring problem.
mess with intermittent electrical connections. I had a
fuel pump harness connector physically break doing
that (and I have poly motor mounts, so not that much
roll). You might get it up on ramps and have a look at
the wiring near the block / exhaust. My headers did a
pretty good job of cooking some wires near the starter
(coated headers, even).
An O2 sensor code often "pins" the affected sensor to
450mV. This will also be the result of an open wire.
If you reset all of the codes and it stays stuck then you
need to start physically inspecting the harness.
Also whats weird is on my interceptor gauge when I flip through the parameters it will monitor if I push the button once on bank 1 it will switch to the next parameter but bank 2 the first push reads a constant 450 but push it a second time & it doesnt change from bank 2, it shows readings similar to bank 1 which looks like everything is switching perfectly.
Also I tried the hard PCM reset last night by:
turning key to "on" position
removed PCM BAT & PCM IGN fuses
let car sit for 5 minutes at least maybe a few more
turned key "off"
replaced fuses
started car
the Service Engine Soon light in the upper right of the cluster was still illuminated like pulling the fuses didnt reset the PCM for some reason. I also pulled the ENG SEN fuse while I was pulling the others & it was in great condition. So were the PCM IGN & PCM BAT fuses.
Talk about make a guy feel stupid, this is all little things slightly overlooked or assumed to not be a issue. Kinda like a slap in the face for exactly why you double check everything & then check it again. So I'm gonna do those things & then he will delete the codes & we will see if they trip again. Now I'm off to search for optimal plug gap for my set-up, LOL.
https://ls1tech.com/forums/fueling-i...injectors.html
I'm guessing leave the out of the box gap on them which I believe should be about .056-.058 although the Autolites come with a .040. With my mods in my sig running pump gas what should I do about the gap for best performance? I'll most likely order a set of GMS wires as well within the next 2 weeks..
My Aeroforce is showing both long trim sitting on 25 but the short trims are staying pretty close together bouncing around. When I got back from a decently long drive I was curious & let the car idle while I unplugged the MAF, not change at all. Idle dipped for a split second & then was just fine. I'm thinkin thats a sign the MAF could have took a dump. Time for some more research, LOL. Its getting closer though, it keeps running smoother & smoother. I can feel it pickin up power as well.
I'm gonna swing by there & lunch & see if a MAF swap fixes it, if so, I might save my money & just go SD and eliminate this problem from ever happening again.
I would run the TR55s at .050
So Speed Density tune here I come.
I'm just to the point that we have narrowed it to a MAF related problem. It'll be cheaper in the long run to go withthe SD tune than buying a new MAF & then paying for a MAF tune. So I'm just goin SD. I have done alot of reading about SD tunes recently and with this shop close enough to me if I ever need a tweak to it I can just stop in. From the work they have done so far though I believe the tune will be up to par. Its still gonna be somewhat safe since its my daily, I'm not gonna have them pull as much as possible out of the combo. No max effort here, I gave up on all that.
