spark plug boot/wire touching header
Old Apr 29, 2011 | 12:27 AM
TA98LS1's Avatar
Default spark plug boot/wire touching header
Just finished my header install and the 2nd and 3rd plug boot on the drivers side are touching the header It hasn't melted them yet but the wires are getting a lot hotter than the others. Is there a different style wire set I should be using or some type of wrap or sleeves?
Old Apr 29, 2011 | 01:30 AM
RodZilla's WS6's Avatar
are you using stock wires?? if so then get some msd's since they have a bend in the boot that hold so it will stay away from the header
Old Apr 29, 2011 | 07:04 AM
TImmy_Jones's Avatar
When I ran MSD wires, i HAD to use a boot protector, it would have melted. I went back to stockers and ran sleeves anyways.
Old Apr 29, 2011 | 07:54 AM
omarrakeen's Avatar
try rotating the boot several times till it clears out. i dont think you will need different wires.
Old Apr 29, 2011 | 08:56 AM
jimmyblue's Avatar
Moderator
I cooked a LS2 OE plug wire with Jet-Hot headers,
ended up with an insulation breach. The silicone is
only going to stand up for so long.
