Is it time for a ported tb or not
Old Feb 24, 2004 | 03:12 PM
dame's Avatar
Default Is it time for a ported tb or not
check sig....... Im about to add a set of A.R.E. stg 2 heads in about a month, im wondering if its about time to get a ported tb (i can get Jantzer ported tb from a friend for $70- thats why im wondering) But i also heard that ported tb's give "tuners" headaches, and that stock tb's are good on 9 and 10 sec cars
Dame
Old Feb 24, 2004 | 03:25 PM
BadAndy's Avatar
The aftermarket MAFs are what cause problems for tuners. Instead of reading incoming O2 accurately, they are actually lying to the PCM in order to lean out the mixture. Bigger displacement and FI engines need a bigger base throttle body platform because of the increased volumetric efficiency. Yeah the stock throttle body is fine for NA stock cube motors. However, these NA 346ci motors can use the increased intake and flow characteristics provided by a ported/polished stock tb. Plus you are def gonna want as much flow as possible so as not to choke the new heads.
Old Feb 24, 2004 | 03:41 PM
dame's Avatar
(this question sounds NooBish- but its not!)
So it's safe to say i SHOULD see some gains with the ported tb, when i put the heads on? (in other words with my set up would you spend $70 on a ported tb?)
Old Feb 24, 2004 | 04:40 PM
BadAndy's Avatar
Yes and hell yes. Since you are using heads that have a greater flow, you will see even more gains than on stock heads.
Old Feb 24, 2004 | 04:59 PM
z2802sunsetls1's Avatar
a ported tb is a must even on a stock car
Old Feb 24, 2004 | 05:05 PM
2001CamaroGuy's Avatar
I noticed an increase when I went from the stock TB to a BBK 80 mm (not really worth the extra money over a ported unit) on a basic bolt on (not even headers) car.
Old Feb 24, 2004 | 07:24 PM
TaTommyWS6's Avatar
Port it yourself for $5 and be done with it. You can remove the material with a dremel, and fill the holes with aluminum epoxy. It is easy and fun!
Here is how mine came out:
http://www.tatommy.com/images/homeporttb.JPG
Tommy
Old Feb 24, 2004 | 08:43 PM
dame's Avatar
[QUOTE=TaTommyWS6]Port it yourself for $5 and be done with it. You can remove the material with a dremel, and fill the holes with aluminum epoxy. It is easy and fun!
QUOTE]
I cant........... i have this disease called LAZYitus...(plus i work 6 days a week)
Old Feb 24, 2004 | 09:26 PM
1RawTA's Avatar
im about to pick up a ported TB this weekend.. i hear its good for 10rwhp on a stock cube engines. i figured i have more exuast going out, so i wanna get more flow going in. since i just installed my headers, it should be a nice piece and boost my HP a little
Old Feb 24, 2004 | 10:09 PM
BadAndy's Avatar
Well I don't know about 10rwhp on a car without heads or at least a cam, but at the very least it will pick up some power and improve throttle response.
Old Feb 25, 2004 | 07:43 AM
jimmyblue's Avatar
Moderator
"There's always room for pie"
Old Feb 25, 2004 | 11:55 AM
dheck's Avatar
For as cheap as you are getting it, I beleive it is a no brainer. Especially on a H/C car. Every little bit helps.
Old Feb 25, 2004 | 01:42 PM
Terry Burger's Avatar
It's usually worth 7-10rwhp on a heads/cam car, and 3-5rwhp on a bolt on car.
Old Feb 25, 2004 | 06:42 PM
1RawTA's Avatar
yea im all bolt on for now, i can see a cam in my future so im gunna just get it now. im also getting it for a great deal without a core
