rough idle like cam
Old May 22, 2011 | 09:49 PM
jasons88gta's Avatar
Default rough idle like cam
I have a 2002 trans am ws6 with 49k. The car has long tube headers with cats slp loudmouth catback slp lid slp maf and 90mm throttle body. It has a very rough idle and shakes sometimes so bad the car cut off. The car is running very rich and im getting horrible fuel milage. i have no check engine light, i have replace plugs and wires the fuel pump/ filter new intake gasket new tps new iac new thermostat and new coolant temp sensor have tested the fuel pressure 58psi not sure what else to do the car runs good when going down the road but when u come to a stop and push in the clucth the car drops to about 500rpm then comes back to about 900. Ive been putting seafoam in it for the last 5 or 6 fill ups and nothing. I was thinking it might be a vaccum leak anybody have any ideas?
Old May 22, 2011 | 10:10 PM
TheSilverOne's Avatar
replace the slp maf with a stock one
Old May 22, 2011 | 10:29 PM
poltergeist 02's Avatar
test your throttle position sensor voltage. if i remember right, it should be around .57v at idle/throttle closed. also make sure that you are at 0% throttle position. you will need access to a scan tool to look at these numbers. once you get it to .57v with the throttle closed you will want to do a tps relearn. this is how: unplug the tps with the key in the off position, now with the sensor still unplugged turn the key to the on position for a few seconds but do not start the car, turn the key back to the off position and plug the sensor back in, now start the car. tps should now read 0% throttle position at idle. this may be an issue with your car but it may also be a vacuum leak as you stated.
Old May 23, 2011 | 04:39 PM
My Tps is showing 3.1% to 3.5% on my scan tool I tried the relearn but it wouldn't reset it back to zero.
Old May 23, 2011 | 05:11 PM
TImmy_Jones's Avatar
Stock MAF is good for 500 HP, get that and a ported stock throttle body!!
Old May 23, 2011 | 07:02 PM
thats a problem. should be 0% what is the voltage at?
Old May 23, 2011 | 07:36 PM
the voltage is .9 lol
Old May 24, 2011 | 10:26 AM
jimmyblue's Avatar
Moderator
Are your O2 sensors 10 years old?
Old May 24, 2011 | 11:22 AM
I know three of the o2s have been replaced not sure bout the fourth the scan tool shows all them working
Old May 24, 2011 | 11:24 AM
I think today I'm gonna put on the stock tb and maf and see if that will fix the Tps
Old May 24, 2011 | 12:08 PM
tripblackls1's Avatar
A faulty map sensor will cause these problems as well
Old May 24, 2011 | 02:01 PM
c0ncEpT's Avatar
Does your HVAC work? Check to see of the plastic vacuum line going into the back of the intake is broken.
Old May 24, 2011 | 06:19 PM
you need to adjust the set screw and get the voltage up to .57 then do a relearn. get that corrected first then move on if the car still doesn't run right.
Old Nov 27, 2011 | 01:02 PM
01CaMMMaro's Avatar
Gonna ttt this, I'm having the same problem. Did the relearn and nothing. I have longtubes and the longer vette O2 sensors and my rears and tuned out. Car drove fine one day and bad idle the next. My car idles around 500 for about 5-10 seconds then picks back up to where it should be. Car drives fine other than the idle though. I have no cats and TSP true duals also. The O2 sensors are maybe 3 months old as well as the plugs and wires.
Old Nov 28, 2011 | 08:36 AM
01CaMMMaro's Avatar
Noticed today that it also drops down then back up when I turn the A/C on.
Old Nov 28, 2011 | 12:34 PM
NY02ws6's Avatar
have you tried cleaning your IAC and TB?
Old Nov 28, 2011 | 01:04 PM
01CaMMMaro's Avatar
No I haven't, today I also noticed that it only goes the rough idle sometimes... Sometimes it starts up fine and sometimes it doesn't.
Should I try some of the spray type sea foam to clean my IAC and TB?
Old Nov 28, 2011 | 03:35 PM
disc0monkey's Avatar
vacuum leak?
Old Nov 28, 2011 | 04:41 PM
thunderstruck507's Avatar
I have a friend whose car has done this for years.
We have looked at and tried just about everything. He replaced every rubber bit on the car looking for a vacuum leak. Maf, tps, and map are all fine. Pretty much given up on it.
Old Nov 28, 2011 | 06:15 PM
can the pcm be fried? i know microprocessors can loose clock speed over time and or exposure to elements
