Summit Cut Out Installed
Old Jun 13, 2011 | 09:40 PM
Wimimc's Avatar
Default Summit Cut Out Installed
i had it for a while but never really got around to installing it till today.
tomorrow i'll get some more pics of it and of the switch. i love it, sounds/feels like a new car.
Old Jun 13, 2011 | 09:49 PM
01ssreda4's Avatar
Is that a Summit branded e-cutout?
Old Jun 13, 2011 | 10:02 PM
Wimimc's Avatar
yes it is,
i love the switch, its almost like a power window/ convertible switch, i put it right next to my fog light switch
Old Jun 13, 2011 | 10:17 PM
StuntmanMike's Avatar
How do you have the cutout itself installed? Are those band clamps? Any leaks?
I've been thinking of installing mine that way, I really don't feel like taking it someplace to have it welded in.
Old Jun 13, 2011 | 10:21 PM
Wimimc's Avatar
i cut out a section of pipe that is a little longer than the y pipe itself. actually my friend cut one end and its at a bit of an angle. i got 3 inch band clamps, ( from summit as well)
http://www.summitracing.com/parts/SUM-693300/
the pipe fit into place butt joint style and the clamps over them. i honestly thought there was going to be a leak but those clamps really sealed well. i haven't lost any ground clearance from the cutout motor as well.
not even kidding, including jacking the car up it took about 15 mins to install the piping/cutout completely. and another 10 or so with the wiring ( did that on a separate day)
Old Jun 13, 2011 | 10:33 PM
NICE!! Thanks for the info! Now I'm tempted to pick up one of these e-cutouts from summit and do the same thing to mine!
Is the switch full open and full closed, or can you open it say halfway for just a little more noise?
Old Jun 13, 2011 | 10:47 PM
Wimimc's Avatar
it operates just like a power window switch, you could have it "cracked" open if you'd like.
Old Jun 13, 2011 | 10:49 PM
Sweet! thanks again for the info!
Hmmm, I think I've found my next mod. Great price on that cutout.
Old Jun 14, 2011 | 08:06 AM
Wimimc's Avatar
heres the switch, i had to square out the hole a bit, then it fit perfect
Old Jun 14, 2011 | 09:34 AM
-Q-'s Avatar
-Q-
Man, thanks for the heads-up...I just went and ordered the cutout, exhaust piping, and band clamps from Summit. Been wanting to do this since I got the new motor in...
Old Jun 14, 2011 | 05:14 PM
Wimimc's Avatar
the route i ran my wire was from the button, behind the bezel, coming out from the back bottom of the dash, under the right side of the console, to under the rear passenger seat. between the console and the seat its visible, i got lazy, but it isnt something i'm unable to mend at a later time.
the location i put the cutout is right next to where the wire comes down out of the hole under the seat.
Old Jun 20, 2011 | 11:23 PM
Clean install on the switch!
I forgot to ask...you're running the stock exhaust? I keep reading the stock I pipe is 2.75"...I'm thinking that's ID? I have a 3" QTP cutout (I just measured it and it's 3" OD), so with the 3" OD clamps, everything will fit together the way you have it?
Originally I was thinking my 3" cutout was big enough to slide over the cut ends of the stock I pipe, meaning I'd need lap joint clamps. That's not the case?
Thanks for the info, I just want to make sure I order the right stuff.
Oh, and how's it sound with the cutout partially open?
I'm thinking I'll run mine closed on the highway, then partially open the rest of the time for a more agressive tone...and fully open will be scaring pedestrians or track use....but mostly scaring pedestrians!
Old Jun 21, 2011 | 06:56 AM
Wimimc's Avatar
no i do no have the stock exhaust, i have a 3" exhaust all around.
however my friend put a 3" cutout on his suburban the same day, and his pipe was 2.75". they used a different kind of clamps and it works, so if you have band clamps it should work. my pipe wasnt cut correctly so i was worried about having a leak, but those clamps seal extremely well.
it sounds pretty good all around, by comparison when its closed it almost sounds like a regular car lol. Since the cutout opens quickly, just a little tap would give you the small opening you desire.
i thought about putting a turndown pipe, but i think i'm just going to put sound deadener in the car.
Old Jun 21, 2011 | 10:50 AM
Mac 2002 SS's Avatar
Very nice install ,man. It seems the motor on the cut-out is very well protected too.
Old Jun 21, 2011 | 07:53 PM
Wimimc's Avatar
thanks, originally i was going to put it where the Y pipe and I pipe meet, but there would have been a lack of ground clearance, moving it back to where that little hump was i was able to aim it upwards a bit.
Old Jun 21, 2011 | 10:34 PM
Oh ok, thanks for the info. Looks like lap joint clamps are what I'll need then.
