Worth it to upgrade headers?
Old Jun 18, 2011 | 09:23 AM
916LS1's Avatar
Originally Posted by LS1WS6dreamer
The BBK LT's from what i've read install easily(fit good). summitracing has free shipping on them right now. Like $369 chrome or an extra $100 for the ceramic coating.
What kind of catted Y fits these?
Old Jun 18, 2011 | 10:59 AM
99Bluz28's Avatar
The bbk lt's come with a bbk ORY-pipe. No cats..
Old Jun 18, 2011 | 11:05 AM
lemons12's Avatar
Pacesetters on average will have the smoothest Install.
Old Jun 18, 2011 | 11:10 AM
TORCHD 02 TA's Avatar
Nothing wrong with 1 3/4" LTs
Old Jun 18, 2011 | 12:21 PM
Paul Bell's Avatar
That's MISTER MODERATOR
1-7/8 LT's WILL make SOME power:
https://ls1tech.com/forums/generatio...p-24-rwtq.html
The argument/statement for smaller primaries holds more true for SBC engines. LS engines flow better and the exhaust matters more. LS engines respond better to 1-7/8 primaries.
Look at it this way: If you're gonna do any performance modifications to your ride, you might as well get the best performing part you can. You'll spend a little more, do the same work but get better result.
Can't afford the better item? WAIT until you can. Save your nickles, save your dimes...
Old Jun 18, 2011 | 01:05 PM
Ehatcher's Avatar
Never had a single problem with my Pacesetters, I really dont see why everyone says "you get what you pay for". My Pacesetter LT's fit great, make great power, were relatively cheap and they have been on the car since early 2005 with ZERO problems in reliability or workmanship. IMO you get a lot more than what you pay for.
Unless Pacesetter quality has went to **** over the last 6 years, I see no reason why you shouldn't get them.
Old Jun 18, 2011 | 01:35 PM
ssdeuce74's Avatar
1 3/4 work great on a bolt on heavy car, if you get the weight down and get heads and cam they still work but 1 7/8 would be better just be honest with what you want to do with the car, and what your money will let you do.
Old Jun 18, 2011 | 03:16 PM
libertyforall1776's Avatar
Lightbulb
You need to qualify that statement -- a blanket statement just doesn't hold-up. At what RWHP levels does 1 7/8 make a difference? THAT is the qualifier. If it made a significant difference with just basic bolt-ons, then you could make that blanket statement.
Old Jun 18, 2011 | 03:18 PM
916LS1's Avatar
From what I've read, the 1 7/8's tend to have more fitment issues due to the larger size pipes...I may be wrong...
Old Jun 18, 2011 | 03:20 PM
lemons12's Avatar
17/8 Have made power gains over 13/4 on si. cars.
Old Jun 18, 2011 | 03:33 PM
Question
"si." meaning what?
Old Jun 18, 2011 | 03:43 PM
  #32
lemons12's Avatar
Stock internal.
Old Jun 18, 2011 | 09:29 PM
  #33
Paul Bell's Avatar
What difference does it make where the gains might be? Gains are gains, wherever they occur. Engine builders make great efforts to gain any amount of power, regardless of how small or large or at what RPM.
Old Jun 19, 2011 | 12:02 AM
  #34
ssdeuce74's Avatar
gains are not just gains IF at peak it must still keep a good curve and the average hp and torque numbers can't go down. You pick up 20hp peak but lose 10 average threw the curve you'll most likely go slower it's not law but i have seen it. Do we have any track comparisons yet thats the number that i'd pay atention too.
Old Jun 19, 2011 | 12:09 AM
  #35
lemons12's Avatar
17/8 will pick up EVERYWHERE compared to 13/4.
Add a good merge and the gains will double.
Main problem with most all ory setups is a **** merge. Put a nice merge on it and pick up power everywhere especially torque as well as better sound.
Old Jun 19, 2011 | 01:50 AM
  #36
Paul Bell's Avatar
^ Agreed
Old Jun 19, 2011 | 08:14 AM
  #37
LS1WS6dreamer's Avatar
Yeah I am not sure if BBK makes a catted Y-pipe or not. There is nothing wrong with the pacesetters. Since I do not need cats I will just be looking for a decent price. BBK or Pacesetter I am fine with both of them.
Old Jun 19, 2011 | 11:54 AM
  #38
916LS1's Avatar
Looks like its going to be Pacesetter since BBK doesn't come with air and egr fittings, and ill have to yank them out every two years for smog. Install ease is a must, and I think ill pick up a ton of HP since im pretty sure im choking my motor right now running shorties with a 224 cam.
Old Jun 19, 2011 | 12:00 PM
  #39
Damian's Avatar
LSX Mechanic
Originally Posted by 808z28camaro
Dont get pacesetters. quality is crap. you get what you pay for. Go long tubes for sure. most torque/ hp gains through out the power band. also sounds waaaay better.
I install 8-10 sets of Pacesetters a month. The quality is excellent for the price, and the fitment is better than Kooks. The only thing Pacesetter leaves to be desired is that **** *** Ypipe, which TSP made a solution for.
To the OP, yes it's worth it to switch. It's not peak power you'll notice the most going to a longtube, but rather more midrange power from better exhaust scavenging.
Old Jun 19, 2011 | 12:06 PM
  #40
916LS1's Avatar
Damian, just out of curiosity, what do you charge to install pacesetters on an fbody?
