Help choosing underdrive pulley
However it's not needed unless you're running something inside the car that requires a larger amount (than stock) of voltage. A large stereo, double din TV's, etc.
That being said, I ran an ASP pulley in my 98 for 7 years with an Eclipse 10" sub and Alpine 300x1(rms) amp with no problems on the stock alt pulley. I saw a tiny voltage drop during certain songs, but nothing to write home about.
Anything larger than a 300w amp might require the ALT pulley, or just run a 1/2 farad power cap.
The new ASP pulley's are SFI approved, and do not come apart.
You can lead a horse to water..............................
Sorry, that made me laugh out loud at work. I rarely hear any belt throwing stories anymore, but for the added security I'm gonna get the SLP/Power Bond for the higher side walls. Wish we could have the best of both worlds and have the ASP with higher side walls.
Stock- 10.5lbs
ASP- 7lbs, has same height belt retention walls as stock 25%
SLP- 10.5lbs 25%
Fluid Dampner- 7.3lbs 10%
PRW- (also Fluid) 12.5lbs 25%
So I am now looking for an answer to the question, does the lighter weight make more power or not?
Manufacturers say weight makes a diff for road racing or circle track not Street/strip.
