My GMMG is hanging low
the camera is on the ground in this pic, so you can tell the exhaust pipes are angled down drastically
i would like it to look similar to this...
Looks as though the tailpipes are welded on so it will be a bit more tricky now, but still doable.
are you guys suggesting to unclamp the area circled and try to re-adjust the catback right there? thats about the only thing i could see that would work.
would it be crazy to take the catback off and then try to have the tail pipes "bent" slightly upward so when i re-install it the pipes will be tucked like i want?
Or cut the tips off, tilt up, and weld back on.
IMO, if the whole catback system is tucked up high close to the body, but from the tail pipes to the tips hang low, then have the shop cut the tail pipes off the ends of the mufflers, reposition them so the ends of the tips are at the desired height you want, then re-weld them.
