rpms hanging up
Would any one know what would cause this issue. Thanks for any help.
1) with key off unplug tps.
2) turn key on while unplugged but do not start.
3) turn key off and plug tps back in.
4) start your car.
what this does is it will reset your throttle position back to 0%. you will need a scan tool/scanner to confirm that you are at 0% throttle position and while you are looking make sure your tps voltage is around .57 when your at 0% tp.
HOPE THIS HELP, before you hurt yourself trying to stop and it don't want to.
As far as a vacuum leak being the issue. I am not sure because the car sometimes idles fine and then bad. Usually doesn't do it till it gets good and warmed up and that is when the 02 sensors would screw up the worst the first time one went out. Either way with high mileage it ain't gonna hurt to replace the other 02 sensor. Will be doing LT's and OR-Y around September.
