maf question
Old Jul 4, 2011 | 09:58 AM
Bowtiedford's Avatar
mine seems to be good and if you looked at the pic its ported.
Old Jul 4, 2011 | 10:00 AM
I will say this, I have about 8" of straight pipe before the MAF and that can make all the difference of straightening the incoming air.
Old Jul 4, 2011 | 10:17 AM
*02WS6TURK*'s Avatar
Originally Posted by cpo
man get out of here with that nonsense....we are all believers in the screen. hell i've even doubled-up my screens thickness just to be really sure no rocks or bushes get sucked in.
De-screening your MAF is considered a "Free Mod" so you can delete one of those you listed in your "Sig".....De-screened MAF & Free Mods that is
And I think I was the only one that caught your sarcasm here
Old Jul 4, 2011 | 10:57 AM
Floorman279's Avatar
so its either buy an aftermarket or leave it alone? if i were to be running a h,c,i, full exhaust 418, how much could i gain oging to a 100mm vs stock
Old Jul 4, 2011 | 11:11 AM
At this point in your build, leave it be and use the stock. If you do that build "418" a GM 85mm MAF would be more then enough. There is only a few HP to be gained when stepping up to larger MAF and that ult depends on the supporting mods. Don't beat yourself up of a MAF. Use your stocker for now.
For example, I put on a 85mm MAF and 98mm Fast Toys lid after my EPS cam swap and only gained a couple HP over my stock set up.
Old Jul 4, 2011 | 12:15 PM
cpo's Avatar
cpo
LS-1 F-Body Free Modifications - Take the Money & Run
One LS1, five free mods, 10 rear-wheel horsepower.
From the August, 2009 issue of GM High-Tech Performance
http://www.gmhightechperformance.com...ons/index.html
Old Jul 4, 2011 | 12:36 PM
Canbarelygo's Avatar
ill say this if you go to a big old 418 why not go sd and punt the maf across the street
Old Jul 4, 2011 | 05:46 PM
cpo's Avatar
cpo
Or go to a little 2L vTec and add 2 triple screened MAF's.
Oh wait, this thread is about LS1's......our bad.
