ARP Crank Bolt
Old Jul 11, 2011 | 08:57 AM
farmington's Avatar
you probably pushed junk into the threaded hole when installing the damper and the ARP bolt probably bottomed out with the junk behind it. I agree that you just might not get this piece out. If you take your time and drill through it with a small drill and progress to bigger ones, you might get it out with an easy out. Take a bolt with the same size and thread and grind a point on it so you get a starting point thats exactly in the middle of the broken bolt. Most important is taking your time, don't rush it and use sharp drills. Good luck.
Old Jul 11, 2011 | 04:52 PM
bayer-z28's Avatar
^FWIW; I've been using Ridgid drill bits at work. Very durable and cryo treated. very sharp and they cut quick too.
Originally Posted by Paul Bell
It's a mystery what happened. We can only assume the crank got damaged the last time the bolt was used to install the damper.
A balancer installer threads into the crank then uses a much larger nut with a thrust bearing to push on the balancer. The threads in the crank, while fully engaged by the tool, is not rotated into under the tremendous stress it takes to install the balancer.
Here's a very good installer kit at a very good price. I've owned a kit just like it for at least 25 years:
[IMG]
THat's what I'm thinking now. Something happened with the threads. Something got bunged up, bound up or JBWeld instead of loctite.
If you snapped it that far in, you've got an issue..
Old Jul 15, 2011 | 10:18 AM
oxblood!z28's Avatar
@farmington I just want to clarify, are you saying use an old bolt with a premaid drilled out hole that can thread in to prevent damage to the crank shaft threads? If so this might work well ...I was thinking of using a hollow pipe that could fit in the crankshaft to prevent any nicking of the threads.
Old Jul 15, 2011 | 10:20 AM
This weekend I won't be getting to the bolt but once I get into it you guys will be the first to know. Thanks for all the input.
Old Jul 24, 2011 | 07:38 PM
Here's how far I got today but I think I need more drill bits and possibly stronger ones. I used the old crank bolt and drilled though that which was pretty easy, this kind of helped with the attemped of drilling the hole in the ARP bolt. It got it pretty center but by the time it came to start drilling the bits were only spotting it. more to come next weekend.
Attached Thumbnails ARP Crank Bolt-nikon-207.jpg   ARP Crank Bolt-nikon-206.jpg
Old Jul 24, 2011 | 07:47 PM
bayer-z28's Avatar
^ What a nightmare.. Sorry dude..
Old Jul 24, 2011 | 10:30 PM
I know it. You mentioned earlier on here about cryo treated bits. Is that something I can pick up at sears or Homes Depot?
Old Jul 24, 2011 | 11:27 PM
clayp's Avatar
I dunno if this would work for you but I've broken a few bolts off inside engine blocks and turbines. I have a welder buddy who will weld up a tab on the end of the broken bolt and then grab it with vice grips to unscrew/remove the piece. Usually takes him maybe 5 minutes to accomplish
Old Jul 25, 2011 | 09:49 PM
Mike52's Avatar
A nice tip that I've used before but in this case the broken bolt is down inside the crank snout, won't be able to weld anything in there to help removal.
Old Aug 8, 2011 | 06:23 PM
Paul Bell's Avatar
That's MISTER MODERATOR
oxblood!z28! How's your dilemma working out?
Old Aug 9, 2011 | 06:30 AM
RezinTexas's Avatar
hopefully you got this resolved by now.
just FYI, you can rent the installer tool at a parts store (Autozone, etc.). Or just buy it from them for about $30.
They also sell them at Harbor Freight
