ARP Crank Bolt
The most common is pictured below. The size for a 5/8 bolt is E5. The drill size for THIS TYPE is 19/64. If you can, find a left hand drill bit (it drills when turning in "reverse" when compared to regular drill bits) and it may just spin out the broken bolt without needing the extractor. The broken bolt in the crank should not be tight as it no longer has a head and isn't clamping anything.
It is IMPERATIVE that you drill in the center of the bolt without hitting the threads. If you hit the threads, the crankshaft will be compromised-you may strip the threads when torquing in the new bolt resulting in a junk crankshaft. Start with small drill bits first. It won't be easy as this is a 200,000 PSI specially hardened bolt, it's stronger than a grade 8 or 12.9 bolt.
But Sears is a good place to get an extractor set. Here's a nice one complete with left hand Cobalt drill bits:
http://www.sears.com/shc/s/p_10153_1...6&blockType=G6
Does the break surface show anything irregular like a bubble or inclusion...?
I'm curious what ARP have to say when they analyze your broken bolt.
I used medium locktite when i installed it. Thanks for the link Paul i just picked up a sears drill bit. hope it works.
Sadly, if this is the case, that broken bit of bolt is never gonna come out. Even the best bolt extractor isn't as strong as the original bolt.
Further, given the bolt's hardness compared to the crank, you'll never perfectly drill it out perfectly on center to tap to the next size bolt, it'll be off center.
It's been said many times here, the damper bolt should not be used to install the damper, it'll tear up the crank threads.
A balancer installer threads into the crank then uses a much larger nut with a thrust bearing to push on the balancer. The threads in the crank, while fully engaged by the tool, is not rotated into under the tremendous stress it takes to install the balancer.
Here's a very good installer kit at a very good price. I've owned a kit just like it for at least 25 years:
http://www.summitracing.com/parts/CCA-4920/?rtype=10
I'd bet you can attribute all of the failures to improper installation, torque, or cleanliness...
