MAF diameter?
Old Jul 10, 2011 | 08:16 PM
VandykeT/A's Avatar
Default MAF diameter?
Can anyone tell me if the overall diameter of a 85mm maf is the same as a stock one? Such as where the bellow would go around it. I know 85 is bigger than 75 but Im thinking maybe its just the inside thats bigger thanks.
Old Jul 11, 2011 | 12:13 AM
2000PewterT/A's Avatar
Not 100% sure, but I believe the 85mm is bigger
Old Jul 30, 2011 | 11:37 PM
fastsspr's Avatar
That is a good question ???
Old Jul 31, 2011 | 01:35 AM
R6cowboy's Avatar
I just measured both of them with the micrometer. The outside diameter of the 75mm MAF (from a 2000 Vette) measured 3 5/8" and the 85mm MAF (from 2005 Vette) measured 3 7/8". These were measured from the front of the MAF's. Hope this helps.
Old Jul 31, 2011 | 04:16 PM
joecar's Avatar
The bellows goes on the rear of the MAF, can you measure the rear diameter...?
Can you remeasure the front in millimeters, please...?
Old Jul 31, 2011 | 07:01 PM
trans_am7935's Avatar
i had a smooth bellow on my stock 75mm one, and then upgraded to a 85mm GM one, bellow slipped on just fine
