For those of you using German Castrol
German Castrol has been re-packaged to reflect this but it is the same made in Germany oil as before.
I'm gonna use it.
There's some of the recent amber GC left on some store shelves like Auto Zone.
It used to be only available at BMW and Porsche dealers.
It tests closer to a 10W-40, not a 0W-30.
There's other technical stuff I won't bore you guys with here.
Many people consider it the holy grail of engine oil-and maintain a healthy stock of it.
I've been using it for about three years now. I recently badly overheated my engine after blowing off the radiator hose then (unwillingly) having to drive two miles with no coolant with the temp gauge pinned high. My (+193,000 mile) engine and bearings have no damage and runs just great today with no noise or smoke in the exhaust whatsoever.
I firmly believe using German Castrol saved my engine from destruction.
OR the newly labeled bottle as shown above that also says "MADE IN GERMANY" on the back panel.
There was a run of this oil that was U.S. made. Do not buy or use it, it's not the stuff.
German Castrol is also our TBSS and my Turbo T.
If I can't get it when I need it, I will pick up Pennzoil Platinum and have good luck, just a little noisier.
After the last Mobile 1 I bought that looked like pouring water, I wouldn't use that **** in my lawn mower.
My stash is down to a dozen quarts. Haven't bought it for approx. 4-5 years. Remember to store it @ inside temps, well above freezing.
Saw a few UOA's on Bobs' a couple of years ago. Felt, @ that time, that it wasn't quite as effective. Haven't checked UOA's on BITOG recently. Never got around to buying any, 'cuz haven't needed it. Will have to buy next year or year after.
Last time I looked into oil performance was when Patman had posted the UOA's from Pennzoil platinum, as an alternative to the green stuff. That's how long it has been.
It's generally a great car. Mine will be the only 460/5 speed ZF tranny Galaxie. Am building & restoring @ an aggressive pace. Biggest hold up has been paint prep, as the guy I bought it from was a complete newb & put literaly thousands of half moon swirls in the original paint & then primered over it. Am not blasting the body. So, getting them out has been a friggin' lot of work. Hope to have her primed in 2K MP182 this week & maybe into applying color coat. 460 & 5 speed installation work is done. It is also getting lowered & has a 9" rear end.
I run mine with those now also discontinued a/c delco gold ultraguard oil filters, AC Delco UPF-44. Last edited by 99'CajunFirehawk157; Aug 8, 2011 at 12:41 PM.
