Pro-M Mafs
Old Mar 3, 2004 | 10:42 AM
Damage Inc.'s Avatar
Sweet Cheeks
Default Pro-M Mafs
Has anyone tried these yet or are we still recommending the stocker. Do you think they really calibrate them correctly or is this just a marketing hype? Any results or gains would be awesome.
Old Mar 3, 2004 | 11:44 AM
2xLS1's Avatar
Pretty sure they were the supplier for Granatelli. Keeping the MAF stock up to around 450hp is the general consensus. Most aftermarket MAFs just cause problems.
Old Mar 3, 2004 | 12:18 PM
jimmyblue's Avatar
Moderator
According to a Granatelli marketing chart I saw
the Pro-M is richer than stock and the Granatelli
"just a little" leaner. Likely that you could adjust
the Pro-M yourself, then, but probably not what
you were looking for.
I'd say until you find a supplier who will give you a
guaranteed frequency/flow data set that you can
tune to, or guarantee within 1-2% of stock cal across
the entire band, it's just more trouble than it's worth.
Unless you like that kind of thing and want to make a
hobby of it.
Old Mar 7, 2004 | 12:24 AM
lsx24's Avatar
If if change your MAF, the Z06 MAF would be the best bet, since it's factory calibrated to a very close version of your engine, and cost <$150 with adapter.
Old Mar 7, 2004 | 01:11 PM
jimmyblue's Avatar
Moderator
No, Z06 cal is almost identical to truck MAF cal
(differences are almost certainly due to screen
and intake tract). On an F-body these MAFs
will put you 15-25% rich and this is not good.
The plus is that you can modify them to be
pretty good fits to the F-body, cheap. But out-
of-the-box, not right. The engine is structurally
the same on a 'Vette but its PCM is programmed
for the proper MAF freq/flow characteristic.
If you were gonna get tuned anyway, you could
just use the Z06 or truck tables and end up in
good shape.
Old Mar 14, 2004 | 04:20 AM
Lt1BadBoy's Avatar
ANSWER: Buy an Lt1 stroke it slap on some slicks and nitrous and call it a day.
Old Mar 14, 2004 | 06:24 AM
jrp's Avatar
jrp
SN95 Director
if the stock MAF is good for people running 10's and 11's then its good enough for me
Old Mar 14, 2004 | 08:00 AM
98SS Blackattack's Avatar
Another wannabe troll
Old Mar 14, 2004 | 01:03 PM
Sweet Cheeks
Ha, sounded too good to be true. Thanks guys. You're right about the Z06 mafs for us. I bought a PACE one with a 85mm TSP lid to match and I threw an SES! I reset the computer and sure throttle response was better, but it didn't pull like the stocker. I have to sell it now. Ha.
Old Mar 14, 2004 | 05:50 PM
jimmyblue's Avatar
Moderator
Before you sell it have a look at this:
http://community.webshots.com/album/95429402bLraTX
If you have any kind of logging / real time display tool you
can tune it in yourself, if you want.
Old Mar 14, 2004 | 06:27 PM
Gev's Avatar
Gev
I picked up 5-10 RWHP and about 7-10 RWTQ all throughout the entire RPM band with my Granatelli MAF. I used an MAF-T to get it to the proper mixture.
Hope that helps.
Old Mar 15, 2004 | 02:57 AM
lsx24's Avatar
Tuning is key.
