Throttle body problems
Old Mar 3, 2004 | 03:28 PM
1RawTA's Avatar
Default Throttle body problems
Well guys, i got a throttle body the other day, it is a stock one ported and polished by east coast supercharging. i put it on before and the wire next to the throttle did not clip on, the metal piece was to big on the east coast S/c one. so i put my stock TB back on. what should i do about the metal stud being to big to fit the plastic clip on the wire next to the throttle cable?
Old Mar 3, 2004 | 08:22 PM
1RawTA's Avatar
anyone ever have this problem?
Old Mar 3, 2004 | 08:26 PM
2w0s060's Avatar
Try callin them, see what they say.
Old Mar 3, 2004 | 08:29 PM
2xLS1's Avatar
My guess is they sent you one with a 98-99 cam. They are different than the 00-02s.
Old Mar 3, 2004 | 09:53 PM
35th SS's Avatar
or its for a truck/suv application.sent you the wrong one.
Old Mar 3, 2004 | 10:17 PM
1RawTA's Avatar
i talked to the guy, supposly its from a 2000. i might swap the whole assembley, and just keep the actuall inlet that was ported. anyone know how to pull the rod out that goes through the TB?
Old Mar 4, 2004 | 10:14 AM
Z06PSI's Avatar
Yes I do..... take off the Throttle position sensor. Take the throttlebody blade out and knock the shaft through the thottlebody on the sensor side. Make sure to catch the retaining ring when it comes out.
Old Mar 4, 2004 | 01:53 PM
1RawTA's Avatar
i figured that, i guess u have to give it a couple hard whacks with a rubber mallet, becuase i hit it yesterday lightly (i didnt wanna break anything) and it didnt budge, and what do you mean by the retaining ring? is that by the bearing inside there?
Old Mar 4, 2004 | 08:13 PM
qwik3r's Avatar
first mistake, going to ECS...
Old Mar 4, 2004 | 09:16 PM
1RawTA's Avatar
i bought it used from someone, i didnt actually go to ECS and have it done
Old Mar 6, 2004 | 12:50 PM
1RawTA's Avatar
well i fixed it, took both the TB's apart, swapped the throttle piece, spring and the big rod that goes through it, put them back together and bolted right up. thanks for the help guys
