best way to run exhaust
https://ls1tech.com/forums/generatio...over-axle.html
There are kits that go over the axle its tight, but I have seen them and they are nice, but expensive. Also, I have passed two years inspection, with no cats, they never look under my car, just plug into the OBD port and it passes. Last year he asked me if it had HIGH flow cats on it, I kinda laughed and said yeah, then he laughed, HE knew.
also any thoughts about running true duals to the axle then a 3" merge and splitting after the axle...how much power would i lose will it sound good? do i even have to worry about it? i'm pushing 400 hp but my goal is closer to 500.
Jack your car up, it hits. Change the shocks, it hits. If you lowered your car and go over a hill, it hits the axle or ground
You're limited to cram the exhaust between the distance from bottom of the axle tubes to the ground. You'll notice this is MUCH smaller than the distance your axle will articulate with normal driving and maintenance
does anybody have any opinions on the setup the muffler shop wants to do?
just to remind everyone this will what it will be after he's done
lt's run to x pipe..running into 2 3" high flow cats all the way to the back axle and then merging into 1 3" pipe then splitting off again into 2 3" or 2 1/2" out to TSP rumblers and out to the bumper with tips.
to me this is basically like a ORY on steroids lol. i was just wondering if anyone has done this and how it flows and sounds. thanks
or
if anyone can help me run 2 3" over the axle let me know
thanks guys
Lots of people have crammed duals and even 4" over the axle with minor mods if anything. If the exhaust shops says you HAVE to run something like 3" then you should just find another willing to think a little
P.S. there relocation kit is also used on kooks true dual setup. GOOD LUCK
why do i need the safety loop?
and if i could just get those foot long pieces of tubing that go over the axle by themselves i'd be in business lol. i doubt anybody can get just those pieces?
you know i would even settle for non-mandrel bends over the axle
Look on ebay for mandrel kits. The shop I like sells defect bends for very cheap in bulk. One kit of 10 bends is plenty for an over the axle job
Aftermarket upper panhard bars built for duals confuse me. It seems like whoever is doing the duals is too lazy to figure out another bend or two to clear the stock stuff. I just crammed 4" over the axle past the stock panhard. I stuck two pieces of 3" in there and theres worlds of room. Why is this even needed?
Punch in mandrel bends into the ebay motors search and you'll see the sets of 10 in both aluminized steel and SS for VERY cheap. They're all defects but I havent found one single bend that was unusable. Cant post the link because they're not a sponsor
Heres just the over-the-axle section of my 4". You can see theres only one intact bend in the whole of it and even it had both ends tweaked slightly. The little ring is actually 3"
