Header Gasket Question
Old Mar 5, 2004 | 10:31 AM
BlackBootyZ71's Avatar
Default Header Gasket Question
do i need to use any kind of lube/tac on the gaskets that came with my FLP's...or do they just seal in dry form?
Thanks,
Mike
Old Mar 5, 2004 | 06:35 PM
Nightclaw's Avatar
I installed mine dry, and have had no leakage issues. Of course, I've only had 'em on for 3 weeks... Frankly, I've never heard of anyone using a sealing material in addition to the gasket alone, but most of my experience up to this point has been with near-stock applications so I may be in the minority...
-Brian
Old Mar 6, 2004 | 12:27 AM
slik98z's Avatar
i haven't tried this on a ls1 motor yet but i had a 95 mustang gt (5.slow yes) but when i installed my long tube headers, i put some, if memory serves me right, rtv silicone kind of sealant, i basically used it to glue the gasket onto the header so it would fit the holes, then i put small amounts on the gasket goign to the head itself. Sealed up great, and they never blew on me. drove with them for about 27k miles before i traded in the car for a 98z28. i took off the headers to return the car to stock form, and the gaskets still looked good, not as good as say a set of metal ones would have looked, but they did their job.
id think u'd have similar results with a ls1. if my stock gaskets are shot, im going to be using the paper **** gaskets that came with my pacesetters and ill be using a sealant on them too. just to ensure easier placement of the gaskets mostly.
just use small amounts if you are going to.
Old Mar 6, 2004 | 06:27 AM
Slowhawk's Avatar
LS1Tech Sponsor
I alway's use the factory gaskets because each FLP I checked was leaking with there gaskets.Alway's out the bottom.
Old Mar 6, 2004 | 09:28 AM
slik98z's Avatar
can you reuse the stock gaskets?
the local dealer is expensive for me if i can reuse my stock ones, that would be tight cause then i dont have to wait for shipping from another web company.
Old Mar 6, 2004 | 10:54 AM
Trans_AmGuy's Avatar
Yes you can! I'm on my second set of headers with my original stock ones.... no leaks!
Old Mar 6, 2004 | 11:29 AM
slik98z's Avatar
haha thats toyte as hell. god damn dealer is probably one of the worst con artists where i live. steel gaskets...64 bux i almost went wacko when i heard that. i mean jebus...64 bucks for a set of header gaskets?!?! why not just bend me over and stick something cold up my butt. thats about the equivilent. ok sorry about the rant. i couldn't believe it.
Old Mar 7, 2004 | 09:28 AM
WILWAXU's Avatar
I would use GM stock replacements dry.
Old Mar 7, 2004 | 11:25 AM
98SS Blackattack's Avatar
http://www.ls1speed.com/cart.cfm
