What is this?
Old Sep 10, 2011 | 03:34 PM
allout06's Avatar
Default What is this?
A while back when I removed my AIR pump I had to remove a vacuum tube that ran to this. I capped it off at the connector you see. When I put a new intake on my car, I ended up breaking the hard plastic vacuum line that goes to the T for the So I said screw it and capped the back of the intake off. Do I need the thing that the electrical connector plugs into in the pic? I want to reconnect my hvac but I have that open plastic line on the passenger side of engine in the back and I don't know were it Shoukd b reconnected.
Old Sep 10, 2011 | 03:38 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Secondary air injector solenoid.
Old Sep 10, 2011 | 03:45 PM
allout06's Avatar
Think I figured it out. One side of the T goes to the back of the manifold, and then the other side goes to that hard vacuum line. and the bottom of the T is connected to the plug in. Right? And the plug in controls the hvac. Right? Lol
Old Sep 10, 2011 | 04:17 PM
allout06's Avatar
Hmm so maybe I'm wrong then? Lol. Do I need it
Old Sep 10, 2011 | 05:02 PM
Paul Bell's Avatar
As it's part of the A.I.R. system that you've removed, you can remove it.
Can we assume you've had the A.I.R. system tuned out?
Old Sep 10, 2011 | 07:34 PM
allout06's Avatar
Ya it's gone. just my hvac doesn't work because of that hard vacuum line towards the back of the intake that T'd into this thing. Can I connect that hard line directly too the back of the intake?
Old Sep 10, 2011 | 08:54 PM
Paul Bell's Avatar
Hvac is your air conditioning?
OK, you've removed the stuff circled in this pic. The line going to the right out of the shot goes to a T-fitting. The other hose on this T-fitting goes to the AC system.
Old Sep 11, 2011 | 10:40 AM
allout06's Avatar
Right. Part of the T connects to the manifold then goes to the a/c system then the other side goes to that electrical piece pictured above. Do I have to have that electrical piece on order for my ac to work again? Or can I connect they AC vacuum line directly to the back of the intake and get rid of that electrical connector and the 2 lines?
Old Sep 11, 2011 | 11:07 AM
Paul Bell's Avatar
Here's the answer:
