moding valve covers?
Old Sep 12, 2011 | 01:00 PM
IKnowtheFuture's Avatar
Default moding valve covers?
anyone mod stock valve covers for shaft mounted rocker clearance? anyone come up with a cheaper way of raising valve covers instead of shelling out the cash for custom covers or spacers?
Old Sep 12, 2011 | 01:26 PM
LS1-450's Avatar
I've modded 'em. It's pretty easy & is the cheapest way. Used a dremmel.
Old Sep 12, 2011 | 01:29 PM
can you go into detail? mine are crower shaft mounts in a etp head.
Old Sep 12, 2011 | 04:56 PM
LS1-450's Avatar
It's been years. Best thing I can tell you is to put grease or similar on rockers, install covers & carefully rotate engine by hand w/ breaker bar on crank bolt. You may even have to remove material in some areas before being able to check the clearance w/ engine rotation. Remove material where the grease leaves a mark in the cover. Continue until everything is clear. That's really all that I did. Afterward, made sure to clean all aluminum chips/residue out w/ brake fluid & air compressor.
Old Sep 13, 2011 | 09:43 PM
Mike52's Avatar
Why use brake fluid to clean the chips, just curious.
Old Sep 14, 2011 | 07:08 AM
LS1-450's Avatar
Meant brake cleaner, not fluid.
Old Sep 14, 2011 | 01:37 PM
sjsingle1's Avatar
i saw that someone makes extra thick gaskets to raise the valve cover......cant remember who
Old Sep 14, 2011 | 03:11 PM
99Bluz28's Avatar
That would be A Yella Terra part, #YT5132.
You can get them at: hinsonsupercars.com
