Coil Pack order
Old Mar 6, 2004 | 10:20 PM
blkbeaZ28's Avatar
Default Coil Pack order
is this the correct coil pack order.
ps . ds
1/8 7/2
3/6 5/4
5/4 3/6
7/2 1/8
Thanks Gilbert
Old Mar 6, 2004 | 11:42 PM
SilverGhost's Avatar
Motorboater
you got em backwards far as i can tell from your diagram thingy.
drivers side of the car starts with cylinder 1/8
Old Mar 7, 2004 | 12:03 PM
blkbeaZ28's Avatar
I wrote them to where 7/2 is the front of passenger side and 1/8 is front of driverside
Old Mar 7, 2004 | 12:05 PM
BlackBootyZ71's Avatar
oh ****, they ARE supposed to go in order????
DAMN! please tell me they are marked!!!!!!!
Old Mar 7, 2004 | 05:07 PM
TTT,
I didn't pay attention to the order of the packs when taking them off...is this going to be a problem (the car fired right up)....Are there exterior marking on the coil packs to differentiate them from one another? (at least i seperated the left from the right!)
Old Mar 7, 2004 | 09:52 PM
2001SS#3013's Avatar
I am confused by what you are asking. The coil packs are referred to as letters. When I had a bad coil pack it referred to it as coil pack E. The was on the number 5 cylinder.
Old Mar 8, 2004 | 12:58 AM
onyxxtreme's Avatar
as far as I can tell, he has em right
2/7 goes on #2, 1/8 goes on #1
btw, 2001SS#3013, he's talking about the sticker above each coil on the wires that says "2/7", "5/4", etc
i didnt know they had letters on em, imma have to check that out
Old Mar 8, 2004 | 08:49 AM
but do the invidiual coils have markings on them? How else would I know which is which?
Old Mar 8, 2004 | 10:47 AM
Motorboater
ah ok, i read it wrong then, we're on the same page.
blackbooty..they are numbered is what we are saying. look on the wire by each coil pack, you will see a yellow tag on there that says the cylinder number that that pack belongs too, it'll say two numbers because the packs are universal, ex: 1/8..so that pack can eitehr go on cylinder 1 or 8..1 being drivers side front cylinder and 8 being passenger side rear. you just gotta make sure they packs are in the proper order on each side of the car.
Old Mar 8, 2004 | 10:49 AM
thanks very much man, that was what i was looking for! I'll have to recheck them as soon as possible!!!!!!
Old Mar 8, 2004 | 11:18 AM
I thought that you could interchange any coilpack with another one. What I meant by the letters is that the computer refers to the location of the coilpack by a letter. Cylinder 1 is A, cylinder 2 is B and so on.
Old Mar 8, 2004 | 12:12 PM
well now i'm confused! Am I going to have an issue if I took them off, and didn't pay any attention to the way that I put them back on? (i guess that is the main issue i have)
Old Mar 8, 2004 | 01:26 PM
Why would the coilpacks be different from one another? They all do the exact samething and have the same voltage or current or whatever it is so why would one need to go to one of 2 cylinders????
Old Mar 8, 2004 | 02:30 PM
that is my thinking...maybe they label them so that they can just say "E=cylinder 5" as pointed out above, but they essentially can go back in any order?
Old Mar 11, 2004 | 04:06 AM
redbandit98's Avatar
i was just scanning along when i came upon this.. Do the coil packs actually have to go back in order? I really couldn't find a straight answer. My car has been down for about a month and i had the coil packs laying on my garage floor in order then my buddy brought his mr2 turbo over to be worked on and with all the **** laying around they got mixed up. I just through them back on thinking there shouldnt be a difference..should there? if so this would mean uneven spark right? i havent started the car bc i have no fuel pump in it yet. Anybody confirm this going back in order is
Old Mar 11, 2004 | 10:08 AM
Motorboater
yes they do need to go back on in order.
for example if you put the drivers side back together and put the harness on backwards..so instead of the first cylinder being 1/8 its 7/2 the car will hardly run and will backfire so bad you'll think you're at war in your garage. it won't get spark properly, car will sound like a carbed car with the timing all buggered up and unburned fuel will puddle in the intake.
They are universal left to right, hence the two cylinders listed for each pack, but they must be in the proper front to back order for the side of the motor that they are on..
Old Mar 11, 2004 | 03:17 PM
damn it..... so the coils are labeled somewhere on the housing?
Old Mar 11, 2004 | 04:19 PM
y2khawk's Avatar
The coil packs themselves don't need to be in any particular order, they are all the same.
The proper order is which plug you plug into a particular coil. #1 is driver front, #2 is pass front.
The coil pack sub-harness is interchangeable side to side, thus they are marked 1/8 2/7, etc.
So feel free to bolt them up wherever, just make sure you have the plugs in order.
Old Mar 12, 2004 | 06:50 AM
sweeeeetttt im ok then.. OBTW that turbo setup.. cant compliment you on it enough; well done my friend. thanks for the reply
matt
Old Mar 12, 2004 | 09:39 AM
Motorboater
dangit, harlan made me realize i was wording it wrong.
yes, the physical packs themselves dont' matter but the harness that plugs into them which has the yellows tags on it is what has to be in the proper order.
