ASP Pulley, New Stock Bolt, Threadlock?
When I put the new stock bolt in for the pulley, I didn't put lock tight on it.
I'm guessing I F'd up. Do you really need the lock tight? I torqued the bolt to spec.
Put 7 miles on the car since I got it running.
What do you guys think? Buy a new bolt, take old bolt out, install new bolt with lock tight or take a chance with the bolt that's in there?
Bill
There wasn't anything on the threads, just the orange stuff by the head of the bolt...
The orange stuff on the head looks like thread locker, they just applied it in a different manner. Needless to say, when I reinstalled my pulley, the new bolt when in as is.
LOL.. that was probably me. I've used a little bit of locktite on my crank bolt ever since then. I've had the pulley off for cam swaps 3 or 4 times since then and never have had a problem getting the bolt loose. The secret to it is to drive the car for 15 or 20 mins and let the crank and bolt get good and hot, the locktite will release easier when it is at a high temperature.
Dan
Also, mine is only torqued to about 190ft lbs and never had a problem. Spec is 240!!!!!
Dan
