Texas Speed Catted Y-Pipe
Old Sep 21, 2011 | 09:41 PM
lil-bit's Avatar
Default Texas Speed Catted Y-Pipe
Ok so im installing the catted Y from texas speed. i have it all bolted together and to the header already. Only thing is that its low and that bracket that holds it up towards the back where the catback and ypipe meet up it doesnt line up to the botom of the car anymore. anybody know if there is another bracket that i need to get or it doesnt go on with this Y. thank you
Old Sep 21, 2011 | 10:23 PM
lil-bit's Avatar
the tunnel brace. thats what i meant is there a different one i need to make this setup fit?
Old Sep 21, 2011 | 10:50 PM
RevGTO's Avatar
Pontiacerator
You can bend the thing and still make it fit. I've done that. I just got rid of it on my current setup.
Old Sep 22, 2011 | 12:46 AM
Mumbles's Avatar
Most people simply remove the Factory Stamped Tunnel Brace when they install an Aftermarket Y-pipe and never look back.
My Bro has the Texas Speed ORY on his SS. There isn't really a way to make it fit without it rubbing the merge on the Y, or mangling the brace.
If you feel the need to have a Tunnel Brace, you should look into getting an Aftermarket Piece that is constructed to give more clearance for larger exhaust.
Old Sep 22, 2011 | 07:26 AM
lil-bit's Avatar
Cool i appreciate it. I didnt know if it would be ok if i completely removed it. Not much holdin up the y an i part
Old Sep 24, 2011 | 11:56 AM
99Bluz28's Avatar
You could make some spacers and shim it down.
Old Sep 24, 2011 | 12:33 PM
LS1CALIBOY's Avatar
I have a TSP ORY and hit rubs aswell but to calm the vibration down I simply took some heater hose sliced it and put it over the edge where it was hitting...
Old Sep 24, 2011 | 07:03 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Remove that brace. It has been removed for aftermarket exhaust combos since 1998!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 25, 2011 | 03:33 PM
lil-bit's Avatar
Lol oh i see i guess im late. Well i dont have that bracket that hooks to the transmission so whats going to hold it up.....
