Flowmaster Super 44 Single??????
Old Sep 23, 2011 | 12:27 PM
firefighter34's Avatar
Default Flowmaster Super 44 Single??????
Looking for someone who has installed a Flowmaster super 44 single muffler...... Either single in/out or single in duel out...... Couldnt find a thread where someone has done it. I would like to put it in like a 80 series and wrap pipe around so I can have true duel exit...... Saw a drawing but cant find where somebody tried... AND no im not doing true duels I dont thing its worth $$.. Bad *** but not worth the $$ to me at this point in my build up.... Thanks for the Help............
Old Sep 23, 2011 | 10:08 PM
Default Anyone??????
Anyone out there?? Any ideas??
Old Sep 24, 2011 | 12:36 AM
99Bluz28's Avatar
You'll have to go with a 3"inlet/2.5" outlets, and a offset inlet will allow the muffler to be positioned better in the stock location. You'll need one FM #9430462 muffler / One Mandrel J-Bend, 2 1/2 in. Diameter, 3 1/2 in. Radius / two 90 Degree, Mandrel Bend, 2 1/2 in. Diameter / Straight Tubing, 2 1/2 in. Diameter, 4 ft. Length..
That should cover all the tubing if you want to run it out to the bumper.
I've ran a FM super 44 before and it sounded great!
Old Sep 24, 2011 | 07:34 PM
Default 2.5?
Aeasome thanks Man, How come the 2.5" outlets? Do they not make 3" outlets? And then if you have a 2.5 " outlets is their any point of 3" header back? I was under the impression that the narrowest part of your exhaust is going to defeat the flow of any larger section? Wise tale?
Thanks
Old Sep 24, 2011 | 07:45 PM
99Bluz28's Avatar
No dual 3" outlets, anyway 2ea 2.5" outlet/pipe will out flow 1ea 3" outlet/pipe.
Old Sep 24, 2011 | 08:29 PM
Thanks Bro....I'll do it than...someones gotta put a super 44 single sound clip on here...... Everybody talks mad **** about flowmaster on here, I get the flow of the 80 series problem but I had one on my last Z with Pace Setter long tubes and no cat....Everyone always told me how bad *** it sounded. It was Loud as ****....I love that flowmaster sound so this should be the best of both worlds with no cross flow problems!
Old Sep 24, 2011 | 10:16 PM
99Bluz28's Avatar
FYI, the center inlet fm s44 (#9430452) will offer better flow than the offset inlet model I posted earlier and still fit good in the stock muffler location. You might want to go with this one for maximum flow from a 3" inlet FM muffler.
Old Sep 24, 2011 | 11:04 PM
sounds good buying it tomorrow!
 Michael S. Palmer
Old Sep 24, 2011 | 11:46 PM
99Bluz28's Avatar
PM sent with shopping list.
Old Sep 26, 2011 | 07:11 PM
kwiksilverz28's Avatar
I did. Single 3 in 3 out. Sounds bad ***. Cheap until I can do true duals or something else....
