Just got my Texas Speed Headers
Jacked the front end up about 3 feet.
Grind down driver side of k-member (for easier install).
Remove driver side motor mount.
Remove oil filter.
Make O2 sensor extensions from junkers, any GM 1996+ rear O2 wires will work.
TUNE!
I did quite a few other things with the header install so it took a while. I ended up putting in new motor/trans mounts (prothane) and that was a big pain, can never get those holes to line up. We also did an AEM wideband, which was money well spent because without a tune we noticed the car doing a 17.1 air/fuel ratio. So we hooked up the HPTuners and tuned it out. We put the wideband on the driver side header O2 sensor bung, and drilled/welded a new bung on the y-pipe for the O2 sensor. Grabbed some rear O2 sensor wires from other 1996+ cars at the junkyard (4 bucks) and voila. The sound is amazing, and the extra horses are noticeable.
Props to Texas Speed and Performance for an EXCELLENT product! Especially for $500, my buddy (welder/mechanic) was stupified by how little they cost. He was though a little puzzled about how the weld on the header where it meets the block was done. Said usually it's welded on the inside and tacked on the outside, something to do with expansion. Where as TSP welded around the outside only, but he also said it shouldn't be an issue for our 500hp goal.
Last edited by Grim Crow; Oct 2, 2011 at 08:23 PM. Reason: to avoid misunderstandings
Grind down driver side of k-member.
Remove oil filter.
TUNE!
Is this something that has to be done for these headers to fit? Hope not or I'll be sticking with Kooks.
So what's up TSP....how do these compare to Kooks? Give us some dyno results!
I'm going to try and fit them in my 68 A Body so picture would sure help out.
Thanks, Tony
