question about coils
Old Sep 26, 2011 | 04:58 PM
OutlawDrifter's Avatar
Exclamation question about coils
what is the difference between the truck "non heat sink" and "heat sink" coils. did some searching but wasn't able to get a real specific answer. any benefits to running one over the other?
Old Sep 26, 2011 | 11:05 PM
01ssreda4's Avatar
They say the heat sink ones are better. I have seen "truck coils" that just look like standard LS1 coils. There are others that are rounded and have the HS on them. It is very easy to see the difference. Depending on hp levels, they may show zero advantage.
Old Sep 27, 2011 | 08:05 AM
what is the heat sink good for? does it just keep the coil cooler?
Old Sep 27, 2011 | 08:25 AM
Darkman's Avatar
Yes, the purpose of the heat sink is cooler operation.
Old Sep 27, 2011 | 09:16 AM
thunderstruck507's Avatar
Supposedly the heat sink keeps the coil cool so the dwell time can be increased.
On a bolt on or cam car I can say for certain there is nothing to gain, it's literally doing work and pissing away money for nothing.
On a forced induction engine I can't say.
Old Sep 27, 2011 | 06:29 PM
thanks for the info guys, piecing together my lsx right now and needed coils, but wasn't sure what the main differences were.
Old Sep 27, 2011 | 06:57 PM
93formto98T/A's Avatar
Coming from a forced induction background I have some input on this. The factory LS1 coils are good to ~1000rwhp FI, the reg non HS truck coils are used on apps over 1Krwhp. I just switched from the regular vortec/mitsu truck coils to the newer HS coils. I made 1200rwhp and 1100rwtq w/o issues on the reg truck coils. I switched to the HS ones only due to the fact that we're shooting for 1800rwhp on e85 which at that power level would be nearly twice the fuel volume per cycle as gasoline.
For anything NA you won't see any improvement in performance over the factory LS1 coils. The truck coils have a higher output since trucks will see a MUCH higher load when towing trailers etc and need it to maximize sustained torque under these extreme loads. If they were of any benifit on NA or lower HP FI cars, GM would have slapped them on the newer vetts and ZR1.
Old Sep 27, 2011 | 08:26 PM
Paul Bell's Avatar
That's MISTER MODERATOR
I had done back to back pulls on a stock motor comparing stock LS1 coils to the heat-sinked truck coils. The motor gained 9.25 HP and 18.6 TQ. Others who've done the same have had varying results, some gained, some did not gain. SOTP measurements also showed a gain and better throttle response.
My opinion? Worth doing it.
Here's everything you need to know.
https://ls1tech.com/forums/12985321-post1.html
Old Sep 27, 2011 | 09:53 PM
sjsingle1's Avatar
who cares.........they look so KEWL !!!! truck coils FTW
