EGR vacuum line?
Old Sep 29, 2011 | 09:13 PM
bobbo489's Avatar
Default EGR vacuum line?
Hey guys/gals, I just swapped my headers and was removing the egr and AIR. When I was removing the part located on the back drivers side of the engine that has 3 rubber hoses going to it and 2 vacuum lines, I snapped one of the vacuum lines, does it go anywhere that would have ill effects on the car?
Old Sep 29, 2011 | 09:17 PM
98 White T/A's Avatar
Removing the EGR and AIR are for emissions, removing them will put the SES light on, but will not affect performance in anyways. I just removed mine this week. The big rubber hose your talking about, yank all that out, it's all for the !AIR.
Old Sep 29, 2011 | 09:20 PM
bobbo489's Avatar
I did take the hose out, I was wondering about the small black vacuum lines that run from that object down the backside of the engine
Old Sep 29, 2011 | 09:25 PM
Not sure if I'm following you. The rubber hose from the AIR pump is big fat hose running along the driver side fender, then runs to the driver side of the engine and splits off into 2 more hoses, one going to the driver side header, the other going along the back of the motor to the passenger side header. All that gets removed, is that the one your talking about behind the motor?
Old Sep 29, 2011 | 09:26 PM
Try to get some pictures, then I could help more.
Old Sep 29, 2011 | 09:33 PM
bobbo489's Avatar
I am trying to email the pic to myself, but google is being annoying. So I will describe it more. It is about 3 millimeters diameter, and rigid. Very easily snapped.
Old Sep 29, 2011 | 10:39 PM
sjsingle1's Avatar
sjsingle1's Avatar
you can block it off at the "T" or block it further up on the hard line
Old Sep 29, 2011 | 10:48 PM
bobbo489's Avatar
So I gotta find something that will block that off at the T there. All the rest of that vacuum line broke off.
Old Oct 1, 2011 | 08:22 AM
Originally Posted by sjsingle1
Both my ls1 and ls6 manifold dont have a t-fitting like that, so what is that from? They both have that plug in the back(big rubber hose, sensor, and small vacuum hose), but not a t-fitting. My vacuum hose goes towards the passenger side, your pic looks like something xtra and goes back towards the driver side.
Old Oct 1, 2011 | 08:27 AM
omarrakeen's Avatar
^ i agree! mine has nothing like that. you actually scared me lol..
Old Oct 1, 2011 | 08:29 AM
I'll brb, gonna grab a pic of mine.
Old Oct 1, 2011 | 08:41 AM
So what intake do you have that has a t-fitting?
Old Oct 1, 2011 | 11:26 AM
omarrakeen's Avatar
^ exactly lol
Old Oct 1, 2011 | 12:24 PM
omarrakeen's Avatar
I just trolled around under my hood. do you mean the T that is under the ecm?? it is WAY far to be reaching the intake? or am i missing something here? mine has the T thingy under the ecm then a small hose runs to the back of the intake...(both the ls1 and ls6 intake have them this way)
Old Oct 1, 2011 | 04:15 PM
99Bluz28's Avatar
Yeah, my 99 doesn't have a "T" on the back like that, I wonder if the 2001-02 have a "T" on the back like that?
Old Oct 1, 2011 | 04:43 PM
omarrakeen's Avatar
okay ive found this weird pic?
could anyone explain what are these vacuum lines for please??i have a single hose that goes to the back of my intake?..
EDIT: another one, its the HVAC vacuum hose..
THIS
wonder wheres the 98-00 HVAC now..
Old Oct 1, 2011 | 04:58 PM
99Bluz28's Avatar
Okay I think this solves it.
https://ls1tech.com/forums/new-ls1-o...cuum-hose.html
Old Oct 1, 2011 | 05:09 PM
omarrakeen's Avatar
wth? i have nothing like that! is there any difference in 98 and 02 hvac lines?
Old Oct 1, 2011 | 06:17 PM
sjsingle1's Avatar
one line goes to the HVAC.....the other to the AIR...........if you eliminate the AIR......you only need 1 line
