Tsp dual sweet thunders help
Old Oct 5, 2011 | 12:34 PM
babbage1109's Avatar
Default Tsp dual sweet thunders help
Tried searching without much luck or pictures. How do you mount the sweet thunder pipes to the underside of the car. They came with hangers but I need some insight or pictures to help guide me before I start this. Any help is appreciated. Thanks in advance
Old Oct 5, 2011 | 02:21 PM
MM98's Avatar
There are two rear seatbelt bolts that go through the floor tunnel.. I would mount the hanger there with a lock nut.
Old Oct 5, 2011 | 02:37 PM
jeepers_88's Avatar
I had to beat the hell out of those hangers with a bfh so they were slanted back towards the front of the car and drilled two holes through the body were the backseat backrest sits up against. You may need somebody to hold the bolt from the inside of the car so it doesnt spin. I wasnt very impressed with the way they mounted but it was all i could think of doing.
Old Oct 5, 2011 | 02:38 PM
I was looking at that. But the hangers are already welded to the resonators I'm thinking about just drilling holes and mounting it to the back. I'll post up a picture or two afterwards
Old Oct 5, 2011 | 06:07 PM
andy-lswon's Avatar
I'm looking at installing some Tsp true duals myself so I'm gonna have the same issues
Old Oct 5, 2011 | 06:56 PM
I just got done. I'll post up a picture and how I did it when I get home
Old Oct 6, 2011 | 11:41 AM
andy-lswon's Avatar
Some pics would be very helpful
Old Oct 8, 2011 | 11:26 AM
1Psycho's Avatar
All I did was just prop the exhaust up as high as it would go and still clear the fuel lines and body, then just marked and drilled holes into the back of the passenger seats and ran the bolts through there
Old Oct 8, 2011 | 01:07 PM
98SSClone's Avatar
Pics would most definitely be helpful. Getting the TSP true duals myself.
Old Oct 9, 2011 | 04:44 AM
BOBS99SS's Avatar
Captain Double Post
we just folded down the back sit ,pulled up the carpet, drilled 2 holes ,put in bolts and done lol, its really pretty easy, for sure helps with a helpng hand, also can gain some clearance if needed by fliping the fuel lines
Old Oct 9, 2011 | 04:53 AM
BOBS99SS's Avatar
Captain Double Post
if you really need pics and help with the install i can get you some pics, i didnt help to much with the install but i sat there and helped , my back was real screwed up the day
Old Oct 9, 2011 | 03:16 PM
I've been so lazy and busy with work I'll post them tonight
if i could change anything i wouldve mounted them higher. but i was afraid of torque arm clearance. i added rubber between the mounts and body of the car to help with vibrations.
