oil dipstick
Old Mar 8, 2004 | 11:15 PM
LS1 Brent's Avatar
Default oil dipstick
Iv'e been reading a few install guides on installing headers. In everyone of them it says to remove the oil dipstick tube. Why is that??
Old Mar 8, 2004 | 11:52 PM
Ferocity02's Avatar
It justs makes the install easier. It's hard enough, you dont need something else to get in the way. It's one bolt and really isnt any trouble to remove or put back in.
Old Mar 9, 2004 | 04:21 AM
ZR2877's Avatar
I am about to get mine installed by someone else but I have been doing a lot of reading and I never heard this. Are you sure they don't mean the drain plug? I read that you might take it out for a little extra clearance.
Old Mar 9, 2004 | 06:47 AM
jpbgto's Avatar
The oil dipstick tube is kinda entangled with the stock headers. You have to remove the dipstick tube completely otherwise the stock headers will hang off it and you will not be able to get it off. All you have to do is remove the 15mm bolt from the side of the block and then with firm pressure pull up on it.
Old Mar 9, 2004 | 11:51 AM
FatZ28's Avatar
Yep.....its not a problem at all and made the header install alot easier.
Old Mar 9, 2004 | 04:32 PM
Derek98z's Avatar
I always take it out. It less than 2 minutes of work.
Old Mar 10, 2004 | 01:20 AM
SapphireHawk's Avatar
Old Mar 10, 2004 | 01:42 AM
DARK AGE 53's Avatar
I think for anyone that tries to install there headers without removing the dipstick first will learn very quickly it needs to be removed.
Al
Old Mar 10, 2004 | 09:09 AM
VoodooWS6's Avatar
agreed!
