BBK Headers or LS6, Which First?
Old Oct 20, 2011 | 09:49 PM
flintwrench69's Avatar
Originally Posted by Joe69z28
On a stock motor your gain maybe 5 hp with LS6 intake.
On a heavy modded motor 8-12hp with a ported LS6 intake.
Not buying it.
Originally Posted by reeperz28
Where are you getting your numbers ? My old 98 gained 16horse and 11Tq with an ls6 intake swap before a tune with just headers and lid only...
That sounds about right. I felt a noticeable difference after the LS6. Much more than 5 hp.
Old Oct 21, 2011 | 12:20 AM
1999transamls1's Avatar
hes talking about gains before headers i would have to imagine, and i would do headers aswell
Old Oct 21, 2011 | 09:14 AM
Rare96LT1Formula's Avatar
The LT headers 20-25hp
This information is not accurate at all.
OP - If you budget permits, finish off your exhaust system. If not, the LS6 intake swap is one of the best bang for your buck mods on the LS1.
Old Oct 21, 2011 | 09:29 AM
Joe69z28's Avatar
Yes thats right 1999transamls1, I said 5hp on a stock motor , stock means the way it left the factory no mods ,no bolt ons, no headers.
Heavy modded motor is minium of heads and cam swap to my way of thinking.
If you doing both LS6 intake and LTs your gain should be over 25hp at least.
I believe OP wanted to known which mod would give more gains on a stock motor, doing one or the other, not both.
Old Oct 21, 2011 | 11:09 AM
bestlude's Avatar
No one is ever going to be "accurate" when it comes to HP gains.. Each car is diffrent. But like stated before, LT's would be your best bet to do first, then the intake.. (get the harder install out of the way) Plus you will hear a difference aswell
Old Oct 21, 2011 | 11:36 AM
You're arguing something that has been proven here time and time again. Bottom line, you're going to see MORE than 5rwhp gains on a STOCK motor when swapping out an LS1 intake for an LS6. It's beside the point right now.
Old Oct 26, 2011 | 08:36 PM
omc8's Avatar
I for one would like to see at least couple or more dyno results on stock motor to see the gain by swapping from LS1 to LS6 intake.The problem is that most guys have done other mods to there cars before they switch intakes,and this corrupts the comparison.
Old Oct 26, 2011 | 08:45 PM
got milk??'s Avatar
LS6 intake may only give you 5-7 peak but the seat of the pants feel is going to be huge. Gains all through the power band. There is a reason GM put smaller cams in the cars that came with LS6 intakes stock and I will tell you it was not for emissons. 1998 Cars have the largest Fbody cams stock so 15-20 hp gains were not uncommon in the day.
Old Oct 27, 2011 | 12:24 PM
Joe69z28's Avatar
It would be interesting to see what one of old cams would do in a stock 01-02 f body.
Old Oct 27, 2011 | 05:40 PM
agenthol302's Avatar
headers and dont look back
Old Oct 27, 2011 | 08:41 PM
moge11's Avatar
LS6... cheaper and waaay easier install. more power with no downfalls whatsoever
Old Oct 29, 2011 | 12:04 PM
  #32
andy-lswon's Avatar
I always heard 01s and 02s had smaller cams to componsite for the extra power of the ls6. I bought the intake and tsp headers at the same time so won't know which gave me the most bc they will b installed together with a tune. I'm hoping for at least 30 with the 2 mods combined with a tune
Old Nov 13, 2011 | 12:34 PM
  #33
omc8's Avatar
I also would like to see what one those old F body cams would do in a bone stock 01 or 02 F body .Or even the cam from a 2000 LS1 vette I think it was a little bigger too 198/209 .500/.500 115.5 LSA. Probably not much of a gain on a bone stock car.
Old Nov 15, 2011 | 10:14 AM
  #34
2nd Gen Fl 'bird's Avatar
LT's will compliment the intake, the intake will compliment the LT's. You will think the part added 2nd is the shiz-nit. Both are proven but, good exhaust should be the starting point. Of course this is IMHO.
