quick injectors question..
Old Nov 3, 2011 | 12:42 PM
omarrakeen's Avatar
Default quick injectors question..
reinstalling injectors. one of them is missing the plastic lock or whatever it is called. can i reuse it without this or is it a must? can i install them with 1 missing or should i remove them all? the 8 o rings are in great condition though..thanks!
Old Nov 3, 2011 | 03:46 PM
omarrakeen's Avatar
ttt anyone??
Old Nov 3, 2011 | 04:45 PM
s346k's Avatar
plastic lock? for the plug itself? or do you mean the metal retainer?
Old Nov 3, 2011 | 05:37 PM
omarrakeen's Avatar
its def not metal if am right..it sits over the O ring (from the intake side not the rail side) it keeps the rubber o ring in place.
EDIT: its the o ring retainer if am not mistaken...comn guys ill have this installed in the morning!
found a pic:
Old Nov 3, 2011 | 07:39 PM
s346k's Avatar
hmm i have no idea. i don't think it would be a good idea, but i'd try it without if i needed the car. it's not hard to pull the rail and you'll know as soon as you turn the key if it is leaking or not.
Old Nov 3, 2011 | 11:08 PM
omarrakeen's Avatar
thanks..anyone else??
Old Nov 4, 2011 | 12:06 AM
Nowhereman's Avatar
Those puppies are under quite a bit of pressure.
I wouldn't chance it.
From the pic, you've lost 25% of the thing anyway.
It will leak.
Old Nov 4, 2011 | 12:34 AM
omarrakeen's Avatar
could someone verify please?
It will leak.
i lost one completely. so its a must then ? guess am going to go look for some..any idea where to order them online.
more info please. going to install them now if it works!
Old Nov 4, 2011 | 12:45 AM
01ssreda4's Avatar
Honestly, for a temp thing, I'd run it. It doesn't alter the O-ring so no the injector will not leak. Downward pressure is what actually keeps the injectors in-place and sealed. I would however, source another injector and scrap that one at the first opportunity.
Old Nov 4, 2011 | 12:48 AM
WS6SP33D's Avatar
As said above as long as the o-ring seals it will not leak. That said if you can find another one (parts house, junkyard) i would def replace.
Old Nov 4, 2011 | 12:54 AM
omarrakeen's Avatar
thanks! holidays are on here for 10 days i wont find any autostores opened plus i honestly dont want to go thru this again! its really a pita plus my intake is off already so ill do it all once. looks like am going to do it and see how it goes.
Old Nov 4, 2011 | 12:58 AM
01ssreda4's Avatar
The bottom ring does not seal against the 59 pounds of pressure from the fuel pump anyway. That would be on the rail side of the injector. You just need that oring to seal against vacuum leaks and such. There is a lot less demand on the lower o-ring, and again, that retainer won't effect it, at least in the short term.
Old Nov 4, 2011 | 01:01 AM
omarrakeen's Avatar
awesome..thanks
Old Nov 4, 2011 | 09:10 AM
omarrakeen's Avatar
done installing it sealed perfect and idles fine...thanks!
