Has anyone tested a throttle body spacer?
Firechicken, I think what your friend with the tpi had is thepart that slips into the front of the throttle body bellow & smooths airflow of blocky factory design. Not a spacer,see nothing in that either{without hoses).
If ya haven,t yet, check out my thread on budget crossram intake. Now that would make a difference if I could pull it off.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
The only TB spacer that actually did anything (moderately) and wasn't actually a spacer was for the 3rd Gen Cammy's and Birds. It was a small piece of aluminum called an air-foil. Actually worked for me. Made the flat spot in front of your plenum pointed so the air went in smooth.Not sure if anyone else heard of these?
