Intake swap emergency
Old Mar 12, 2004 | 02:57 PM
99ZEOD's Avatar
Exclamation Intake swap emergency
I'm swapping my LS1 intake for a LS6 and after I pulled it off I noticed the parts guys only gave me one coolant plug for the back. I can't get another for a little while but I really need my car. Can I modify one from the old coolant line? I was thinking of cutting one off the old line and sealing the end with some RTV and a screw or something like that. Would this be an option or am I dreaming?
Somebody please help!
Old Mar 12, 2004 | 04:26 PM
Damian's Avatar
LSX Mechanic
Yeah your best bet would be to cut off one of the plugs from the old coolant line and epoxy it shut. Make sure it's FULLY cured before putting it back on the car......
Old Apr 21, 2004 | 06:05 PM
v8maro's Avatar
What kind of epoxy should I use??
Old Apr 21, 2004 | 10:48 PM
v8maro's Avatar
I bought some 2-part metal epoxy where you have 2 tubes and u mix them, should this work?
Old Apr 22, 2004 | 02:20 PM
v8maro's Avatar
ANyone?
Old Apr 23, 2004 | 06:32 AM
Blorton's Avatar
If you're talking about JBWeld, that'll be fine. Like the other guy said, make real sure it's good and cured before putting it on the car. 24 hours would be good.
And you'd be surpised at what can be fixed with JBWeld. I've heard of people fixing cracked dirt bike frames with it and the repair holding up permanently.
And don't forget the surfaces that the jbweld is to be used on have to be super clean. Brake cleaner is good for that.
Hth,
Dan
Old Apr 23, 2004 | 06:59 AM
rons 00z's Avatar
i used some hose and the old coolent lines and made me a piece in the back. not it goes behind the oil sensor and over to the other side
Old Apr 23, 2004 | 09:49 AM
v8maro's Avatar
well, i got some epoxy stuff that sets in 4mins and is useable at 4hrs and is cured in 15-24hrs depending on heat
If i use a blow drier to harden it, do you think that willl help it?
-Steve
