California guys, or whoever knows CALI laws...
I want to get some headers but I want the car to be legal and with cats, which headers do you suggest? not looking for anything crazy, I just want to open her up a lil bit. thanx guys
You change the exhaust system, you are toast.
The best thing you can do is make friends with some guys who do smog stuff and send em a bottle or 6 pack when it gets close to smog time.
On the 99 the double walled pipe on the passenger side between the cat and the manifold that's your biggest/worst restriction on the stock exhaust. Replace that with some single wall SS tubing, and a better merger on the Y-pipe would help some to. I'd replace the ls1 intake with a SLP LS6 w/egr , port and/or mill the stock heads or if you can afford it get some AFR 205's or 210's, I also get a small cam with at least -4* valve overlap. A good example is a 224/224 114lsa.
