Engine dowel pin
Old Nov 24, 2011 | 10:50 AM
Beeterolds's Avatar
Default Engine dowel pin
I bought a good 5.3 a while back and noticed its missing an engine to transmission dowel pin, ya know theres 2 that locate and center the transmission to the engine, does anyone have a spare floating around they wouldnt mind selling me?
Old Nov 24, 2011 | 10:59 AM
zipster's Avatar
I had the same problem, I got these
http://www.jegs.com/i/Moroso/710/37932/10002/-1
Old Nov 24, 2011 | 04:26 PM
Beeterolds's Avatar
I just got back from my parents house for dinner... My dad gave me a piece of .625 solid brass... I mean since theres no real load on this pin other than to line up the engine and transmission I feel it will be ok.. Ill cut it to fit, and chamfer both ends so there is no sharp edges.. then ill warm up the hole with a propane torch on low and toss the dowel in the freezer and hopefully it should slide it with some light tapping..
Old Nov 25, 2011 | 10:43 PM
Revoroller's Avatar
Doubt you'll have to heat it up at all, my 5.3 was missing one also and I used a punch and hammer and got one from my ls1...just tap it from the back side.
Old Nov 27, 2011 | 12:39 PM
Beeterolds's Avatar
Your right, i chamfered the edges and tapped it in, worked perfectly.. i love freebies!
Old Jul 19, 2017 | 08:12 AM
Fearless427's Avatar
Don't want to resurrect a years old dead thread, I installed my motor into the car with a missing dowel pin. Obviously i need to put a new one in. When you say that you tapped it in from the back side do you mean the transmission side or the back side being the front of the car, in an installed position?
I'm hoping its the latter.
