any ported bbk intake results?
LS6=10lbs
24-10=14lbs
Not trying to be an ***, just trying to show allllllllllll that added weight isn't allllllll
that much(+14lbs). Run 2 less gallons of gas in the tank if it bothers anyone
that much. See how insignificant it really is? Still want to see results on testing the two intakes if anyone has the data. Sounds like there are positive results. How much is the question.
Regarding the head soak issue. One can get the inside of the runners coated with a ceramic thermal barrier. I have done it with my highly modified TPI intake manifolds. Also you can get the outside coated with a heat despersent. There are ways around the issue if one feels it is important. IMHO I think the BBK intake manifold would be a big positive in the hands of a good porter.
