any ported bbk intake results?
i painted my intake, and the clear coat turned yellow after it got hot. and it was high temp, so it looks like ****..... then my fuel line spewed gas all over it and took off some of the paint. its too cold to mess with it now, ill repaint it next year. MAKE SURE YOU LOCTITE THE BOTTOM PLATE BOLTS IN. 4 of mine were almost all the way back out and one was sitting on the plenum. i removed the gasket and RTV's the whole bottom plate then blue loctited the bolts in.
no port job here though. the inside is really smooth and not rough like a casting like u would think.
the day i painted it...
Going from a stock LS1 intake and bolt on 98 LS1 to a BBK ported intake and no other changes. Then a tune to see how it does after that. The Best V8 Stories One Small Block at Time
My intake hit the crossover coolant lines in the back
. So I had to make a work around for it...
Going from a stock LS1 intake and bolt on 98 LS1 to a BBK ported intake and no other changes. Then a tune to see how it does after that.Like it says, If your going from a stock ls1 intake the BBK is better than an ls6 and not much more money. I would expect even more from a ported one..
