New exhaust causing trunk rattle. Can't find it.
I just had the quad tip Magnaflow kit installed in my TA. Combined with the cam and longtubes, it sounds phenomenal. Unfortunately, I'm now getting a rattle in the hatch area somewhere from the vibrations. Is there anything in the hatch that is common to rattling? It sounds very thin and plastic like, which is 90% of the trunk. lol Ideas? There currently isn't a license plate on the car, so that's not it.
I did just discover that the over the axle part of the exhaust is sitting on the panhard bar. Maybe once I move it away from that it'll quit sending so many vibrations into the trunk. I like the foam idea though. I feel silly for not thinking of that. I was just sitting here wondering how one would stop rattles from the heatshield, short of removing it.
My over the axel part of the I pipe was touching the frame and made noise. I tried wedging a small piece of rubber hose between the frame and pipe, worked great but would eventually fall out. Solution: I took a screw clamp and ran it through the piece of rubber hose, then wrapped/tightened the screw clamp around the I pipe so the rubber hose was in place, secured by the clamp. Never a problem again.
